Old 04-04-2014, 01:10 PM   #1
1974 Argosy 20
Kooskia , Idaho
Filiform/Entry handle, 2014 FC 20
I just thought I would post these two photos of the Filiform Corrosion on the entry handle of my 2014 FC 20'.
The trailer was purchased in late June 2013. I traveled about 7000 miles with it last summer. It has never been near salt, either road or ocean varieties. It is stored under an open carport next to a fresh water river in Idaho.
I winter in AZ. When I left November 1, there was no indication of any problem. When I returned on April 2, I found what you see in the photos. There is no other indication of Filiform any other place on the rig. What you see on the handle is near the center, not where the handle attaches to the wall. There are rubber gaskets between the handle and the wall aluminum.
Of course I will bring this up with my dealer but I am not expecting any resolution of the problem. I find it strange that it should appear only on the handle in the center part, and while undercover, although in a location where condensation can occur on the rig.
Any comments are welcome.
ID:	208958   Click image for larger version
Old 04-04-2014, 02:00 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Probably got the salt and moisture from your hands. Seriously.
Should be easy to clean up though. I wipe ours with some CorrosionX as well as other accessories and exposed edges on the trailer. No corrosion so far.
We have been in the Southwest three winters now with this Airstream.
Doug and Cheryl
Old 04-04-2014, 07:30 PM   #3
richw46's Avatar
Lexington , Kentucky
I was thinking scratches from rings or keys, then salt from the hands. They look like all the little surface scratches around the door handle on a car.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 04-04-2014, 07:42 PM   #4
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Ours has the same crap on it. All corrosion. I would sand it, maybe steel wool and then reseal it.
subfan1 is offline   Reply With Quote
Old 04-04-2014, 08:09 PM   #5
1974 Argosy 20
Kooskia , Idaho
Nope, not scratches. It is little worm tracks of corrosion. I am single, wear no rings and unlock the door, drop keys back in my pocket, then use the handle to assist entry most of the time. Also, it was not there on Nov 1, but occurred during the 5 months I was gone this winter.
Old 04-04-2014, 08:55 PM   #6
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Is there a reason to expect this won't be covered by warranty?
kscherzi is offline   Reply With Quote
Old 04-04-2014, 08:56 PM   #7
dkottum's Avatar
You guys been sitting outside dipping into the potato chip bag getting that salt and oil all over your hands?
Doug and Cheryl
Old 04-04-2014, 08:58 PM   #8
dkottum's Avatar
I think corrosion is specifically excluded under the warranty but not unusual for them to fix such things in "good faith".
Doug and Cheryl
Old 04-04-2014, 09:11 PM   #9
JFScheck's Avatar
Rockville , Maryland
Images: 33
Same on my 2013, bad batch?
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-04-2014, 09:13 PM   #10
kscherzi's Avatar
Images: 24
I think refusing to replace the handle (what, $25 max?) is just wrong. I've camped most of the past year with my 2013 and don't have any corrosion. Your handle, just months old, is obviously defective. Seriously, if they (Airstream) don't replace it I'd take them to small claims court just to make them spend $$$ on someone to travel out and defend their position.
Old 04-04-2014, 09:27 PM   #11
dkottum's Avatar
I think replacing the handle involves taking it to the dealer, removal of the interior cabinet and drilling out the rivets to pull back the interior aluminum? I would just tape it off, clean it up and refinish it with some clear acrylic.
Doug and Cheryl
Old 04-04-2014, 11:40 PM   #12
1974 Argosy 20
Kooskia , Idaho
Yes, corrosion is specifically excluded in the warrantee statement. I read it again this afternoon. I have some other dealer work that needs to be done, it will be interesting to see what they say about the handle. As someone has said, it is not an easy replacement item. Now, the lower door hinge is loose, and that also is not an easy repair, but one which is critical, no matter how difficult the job.
But a 400 mile round trip, so I don't just run to them at a drop of the hat.
Old 04-04-2014, 11:44 PM   #13
1974 Argosy 20
Kooskia , Idaho
I re read my original post and now see that I didn't make it clear that the trailer was in Idaho all winter, untouched, under the carport storage area. I did not use it for 5 months. The corrosion was not there when I left, but was when I returned home.
Old 04-05-2014, 12:09 AM   #14
2008 31' Classic
Lake Charles , Louisiana
They just don't make them like the use to. We have had to deal with small corrosion issues the whole time we have owned our trailer. You have to stay on top of it and make sure you keep CorrosionX around the house. My parents have a 1990 model and my dad does little more than wash it. His trailer shows NO signs of what I have to deal with. But with that said.... we still use and enjoy the trailer. Just takes a bit more to keep it up :-)
Steve & Mary is offline   Reply With Quote
NorCal : 2014 Jackson Rancheria Rally, October 10-12, 2014 Coastalview Forum Rallies & Meet Ups 240 01-03-2015 02:04 PM
1978 Argosy 27' Entry Door Handle Repair 1978Argosy27 Doors & Locks 1 09-04-2012 03:33 PM
Filiform Corrosion? Harper Ribs, Skins & Rivets 7 06-08-2008 10:45 AM
Filiform corrosion Brad Hunt Ribs, Skins & Rivets 4 11-19-2007 12:17 PM
entry door handle lido&linda 85/345 General Motorhome Topics 14 06-27-2006 05:46 PM
