Old 11-03-2010, 07:51 PM   #1
uncledan's Avatar
1966 17' Caravel
College Station , Texas
faded emblem
We have a 66 Caravel that has a badly faded emblem.
Any ideas how we can get the blue back in our Airstream?
Name:	not so blue.JPG
uncledan is offline   Reply With Quote
Old 11-03-2010, 08:20 PM   #2
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Uncledan,
I masked the silver letters with green tape and an exacto knife. Sprayed the background with (sand lightly first) auto primer and Rust oleum -Royal Blue. They turned out really nice.
Tim
Beaker63 is offline   Reply With Quote
Old 11-03-2010, 08:26 PM   #3
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
Vintage trailer supply .com sells them cheap!
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 11-03-2010, 08:34 PM   #4
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Airstream
Bought mine at Vintage Trailer Supply.By the time I had bought the primer the paint not to mention the time involved I went for the reproductions(which are exact).I did my flags and my International tags however.The flags took forever, but look great.
bwaysteve is offline   Reply With Quote
Old 11-03-2010, 08:39 PM   #5
That Airstream name plate is still available from some Airstream dealers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-03-2010, 08:46 PM   #6
Beaker63's Avatar
1963 16' Bambi
It was very time consuming, all that cutting and taping. Then there is the issue of blue paint on the kitchen table. Yikes!
I did find that under the rear emblem Pablo had signed his name in really tiny letters. What do ya think he's doing these days?
Tim
Old 11-03-2010, 08:47 PM   #7
NicheVintage's Avatar
1965 26' Overlander
Scottsdale , Southwest
Images: 34
Try clear contact paper and an exacto knife. Works like a charm and will stick well to the raised letters.
NicheVintage is offline   Reply With Quote
Old 11-03-2010, 08:54 PM   #8
Beaker63's Avatar
1963 16' Bambi
Better idea.
Tim
Old 11-03-2010, 09:10 PM   #9
1965 26' Overlander
Images: 34
Here are some pics from when we did ours.
Total cost for this project just under $10
ID:	114502   Click image for larger version
Old 11-03-2010, 09:34 PM   #10
1988 25' Excella
Trumbull , Connecticut
I removed mine from trailer. cleaned them and sprayed them with royal blue rustoliom.
when dry I took a small orbital sander and went over the raised letters to sand the blue paint off (easy). then I gave the whole thing a coat of clear. except for drying time it took about 50 ninutes for all 4 emblems. regards nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 11-03-2010, 10:17 PM   #11
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
frame
So, where can I find 2 frames for my '64 emblems like the one Niche Vintage shows on '65?
Nicely done.
Safari64 is offline   Reply With Quote
Old 11-04-2010, 04:20 AM   #12
Nicely done.
That framing is no longer available, from Airstream.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-04-2010, 05:21 AM   #13
Waters , Michigan
Are the emblems bucked or pop rivets?
PINKBIKE is offline   Reply With Quote
Old 11-04-2010, 05:51 AM   #14
Baltimore , Maryland
Nicely done.
You make it... Vintage Trailer supply sells the "j" edging. Just cut the corners with snips on a 45 and rivet it in place.
Old 11-05-2010, 05:53 AM   #15
1978 28' Ambassador
Savannah , Georgia
I am beginning to work on my International emblems. Someone suggested putting a light coat of vasoline on the top of the raised letters. This seems like a good idea. Once I have sprayed the red, white and blue areas then exposing of the letters should be an easier task. Question: once you have sanded all areas, what primer color do you suggest? Also color choices? Blue= Royal Blue; White= White; Red= what color? Also should one use gloss, semi-gloss or matte finish? Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 11-05-2010, 07:42 AM   #16
funkill's Avatar
Tucson , AZ
Images: 27
I didn't have an Vaseline but used Vicsk's VaporRub - worked fine. Tried using chapstick directly from the tube but it got clogged in the lettering - probably could have put it on my finger and transferred it easily. Remember, light coating --- just put some on your fingertip and tap most of it off before tapping it onto the metal.
Laura
funkill is offline   Reply With Quote
Old 11-05-2010, 07:52 AM   #17
1977 Argosy 24
Milltown , Wisconsin
I would think sanding the paint off would work better then greasing the letters. It shines up the aluminum and doesn't risk the paint coming off where you don't want it to because of misplaced grease. The break between the aluminum and background color would be crisper also. Then the clear coat over everything protects the color and the aluminum from tarnishing. Just my 2 cents worth after painting cars for 40 years.
ventport is offline   Reply With Quote
Old 11-05-2010, 05:37 PM   #18
Silver Mist
LI Pets's Avatar
Riverhead , New York
I used a razor blade to removed the paint on the raised letters
Old 11-11-2010, 05:10 PM   #19
jerbear315's Avatar
1966 17' Caravel
Images: 22
Oops bought white contact paper. Will go get the clear.
So, how close is the royal blue to the original color?
Buying the reproduction means having to learn riveting- yikes. It has to be done at some point...
Jerri
(uncledan's wife.)
jerbear315 is offline   Reply With Quote
Old 11-11-2010, 07:31 PM   #20
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Did the front "AIRSTREAM" on the Trade Wind this afternoon using the clear contact paper technique. Worked like a charm. First I gave the whole thing a good scrubbing with a green scotchbrite pad. Then I polished the aluminum that was not to get paint with a dremel and felt bob with Flitz. Cleaned everything with acetone and covered the whole area with clear contact paper ( Wally World for about $6). I was down to my last exacto blade and having a new sharp one would have really made cutting out the letters a lot easier. Rustoleum Royal Blue was sprayed shazaammm. Didn't make a pic, but it looks great and total cost was less than $10. Got to do the rear emblem tomorrow.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Exterior Emblem StingrayL82 Clearcoat, Exterior Paint & Trim 72 12-18-2011 11:07 AM
Help with emblem wbcc65ovrlnd Clearcoat, Exterior Paint & Trim 12 10-28-2010 07:28 AM
Really COOL faded plastic restoration info! Keyair General Interior Topics 8 10-17-2010 09:55 AM
looking for '63 Tradewind emblem 1963tradewin 1959-69 Tradewind 9 11-10-2009 11:42 AM
Airstream Names Faded Aria Clearcoat, Exterior Paint & Trim 10 11-14-2006 06:50 PM
