Old 11-05-2010, 05:53 AM   #15
1978 28' Ambassador
Savannah , Georgia
I am beginning to work on my International emblems. Someone suggested putting a light coat of vasoline on the top of the raised letters. This seems like a good idea. Once I have sprayed the red, white and blue areas then exposing of the letters should be an easier task. Question: once you have sanded all areas, what primer color do you suggest? Also color choices? Blue= Royal Blue; White= White; Red= what color? Also should one use gloss, semi-gloss or matte finish? Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 11-05-2010, 07:42 AM   #16
funkill's Avatar
reno , NV
Images: 27
I didn't have an Vaseline but used Vicsk's VaporRub - worked fine. Tried using chapstick directly from the tube but it got clogged in the lettering - probably could have put it on my finger and transferred it easily. Remember, light coating --- just put some on your fingertip and tap most of it off before tapping it onto the metal.
Laura
funkill is offline   Reply With Quote
Old 11-05-2010, 07:52 AM   #17
1977 Argosy 24
Milltown , Wisconsin
I would think sanding the paint off would work better then greasing the letters. It shines up the aluminum and doesn't risk the paint coming off where you don't want it to because of misplaced grease. The break between the aluminum and background color would be crisper also. Then the clear coat over everything protects the color and the aluminum from tarnishing. Just my 2 cents worth after painting cars for 40 years.
ventport is offline   Reply With Quote
Old 11-05-2010, 05:37 PM   #18
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I used a razor blade to removed the paint on the raised letters
'77 Sovereign Intl 31' CB
Old 11-11-2010, 05:10 PM   #19
jerbear315's Avatar
1966 17' Caravel
College Station , Texas
Images: 22
Originally Posted by NicheVintage View Post
Try clear contact paper and an exacto knife. Works like a charm and will stick well to the raised letters.
Oops bought white contact paper. Will go get the clear.
So, how close is the royal blue to the original color?
Buying the reproduction means having to learn riveting- yikes. It has to be done at some point...
Jerri
(uncledan's wife.)
jerbear315 is offline   Reply With Quote
Old 11-11-2010, 07:31 PM   #20
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Did the front "AIRSTREAM" on the Trade Wind this afternoon using the clear contact paper technique. Worked like a charm. First I gave the whole thing a good scrubbing with a green scotchbrite pad. Then I polished the aluminum that was not to get paint with a dremel and felt bob with Flitz. Cleaned everything with acetone and covered the whole area with clear contact paper ( Wally World for about $6). I was down to my last exacto blade and having a new sharp one would have really made cutting out the letters a lot easier. Rustoleum Royal Blue was sprayed shazaammm. Didn't make a pic, but it looks great and total cost was less than $10. Got to do the rear emblem tomorrow.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Exterior Emblem StingrayL82 Clearcoat, Exterior Paint & Trim 72 12-18-2011 11:07 AM
Help with emblem wbcc65ovrlnd Clearcoat, Exterior Paint & Trim 12 10-28-2010 07:28 AM
Really COOL faded plastic restoration info! Keyair General Interior Topics 8 10-17-2010 09:55 AM
looking for '63 Tradewind emblem 1963tradewin 1959-69 Tradewind 9 11-10-2009 11:42 AM
Airstream Names Faded Aria Clearcoat, Exterior Paint & Trim 10 11-14-2006 06:50 PM
