Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 06-16-2009, 06:58 PM   #1
Profile:  1987 23' Sovereign
Ft.Worth , Texas
Exterior Wax
Has anyone tried to use Turtle Wax 'Ice' on an A/S with plasticoat?
From what I've read about the product it seems like it is ideal for this application. It says it seals and leaves no white residue behind. I have never used the product but have talked to people who use it on their cars and trucks and say that you can even use it on the rubber and plastic trim.
What do you think?
Old 06-16-2009, 10:01 PM   #2
2dabeach's Avatar
Profile:  2007 25' Safari FB SE
North/East , New Jersey
What do you think?
Bluto.... I've used the Turtle Wax Ice on my 95 Bonneville and I'm not impressed. It's hard to apply as it's clear and difficult to see on the paint. The paint on the car is no longer in top shape and the Ice did very little to shine it up. It will make the rain drops bead on the paint when it rains. The good thing about the wax is that it is great on the black plastic trim around the door handles and fender wells on my GMC. I only use it on the black plastic as it will usually remove the white wax stains I get on the plastic trim when I wax my truck. I would have probably sent it back to Turtle Wax for a refund if it wasn't so good on the black plastic. I only use the Walbernizer RV Super Seal wax on my Airstream.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
WBCCI # 8459
2dabeach is offline   Reply With Quote
Old 06-17-2009, 01:57 PM   #3
Commercial Vendor
Profile:  Corona , California
What do you think?
Unless your trailer has been replasticoated, the paint has been shot years ago.
Plasticoat is good for only about 5 years.
Do you really want to rub anything on dead paint?
To do so, may remove some of that paint.
Walbernize is the top choice for plasticoat protection.
It's available from a few Airstream dealers.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 06-18-2009, 09:43 AM   #4
Ft.Worth , Texas
Thanks guys, Walbernize it is!
Old 06-18-2009, 09:56 AM   #5
Profile:
Vinegar: I used diluted vinegar on the stone shields to remove last fall's (now fossilized) smashed bugs on our '03 30' A/S. It worked great! (Winter comes at any time in the Upper Great Lakes and there was no time to do it before winter). Any downside to now using vinegar on the front of the trailer to remove the rest of the bug carcasses? Wikipaedia says vinegar is a mild acid used for centuries. Will it discolor the clear coat?
oakwood is offline   Reply With Quote
Old 06-18-2009, 11:16 AM   #6
CA Streamer's Avatar
Profile:  2005 28' Safari S/O
Atascadero , California
Images: 20
I use Walbernize and it works great on the clearcoat. The only downside is it will leave white residue around the rivets and decals and it needs to be reapplied at least twice a year.
Steve-- "Mongo only pawn in game of life"
CA Streamer is offline   Reply With Quote
Old 06-18-2009, 11:37 PM   #7
Ft.Worth , Texas
I have never used vinegar on an Airstream, but can say that with the older Plasticoat finish I have used kerosene added to my bucket of wash water with soap and it cleans off just about everything from bugs to tar to diesel smoke residue off the finish. Then wash with just plain soapy car wash water then rinse, then wax, in that order.
I heard about using kerosene from an Airstream publication that used to have a section about tech tips.
I have also went one step further and have used this on the lower body panels on my truck with no ill effects on the clearcoat paint. Just don't get it on the windshield or wiper blades.
Old 06-19-2009, 06:16 AM   #8
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 45
I am using "Ice" on our car and really like the shine, application, and durability. Ice is not a cleaner so the surface must be in top condition before using.
On our 23 I have used a number of car wax products on it and apply Spring and Fall.
I have a bottle of Walbanize but don't care for it even though it may be the best product for the Airstream surface.
Road Ruler is online now   Reply With Quote
Old 06-21-2009, 03:17 PM   #9
64airstream's Avatar
Profile:  1964 22' Safari
Beaver County , Pennsylvania
I'm trying a little experiment with "Ice" right now. As I do this year's aluminum polishing (no clear coat), I'm topping a few panels with "Ice" to see how it holds up.
What I found, so far, is that the "Ice" pulls the residual aluminum oxide (black residue) up like mineral spirits. So, I coat a small area with "Ice" and immediately wipe with a clean cotton rag. Then I apply the "Ice", let it dry to a haze and buff it with a microfiber.
I'll let you know at the end of the season how it did, I'm figuring, worst case, Nuvite will take it off next spring. Of course, it could come off in little hard flecks and scratch everything to .... But, that seems unlikely.
Roy
64airstream is offline   Reply With Quote
Old 06-21-2009, 04:23 PM   #10
maccamper's Avatar
Profile:  1974 29' Ambassador
Bloomington/Normal area , USA
carnuba wax
I will be polishing for the first time this year and have already found out that P&S will not clearcoat a trailer that they don't polish.
It looks like I will be waxing over the polished aluminum, has anyone tried a good quality carnuba wax? Thanks.
maccamper is offline   Reply With Quote
Old 06-27-2009, 01:16 PM   #11
finalcutjoe's Avatar
Profile:  2008 30' Classic S/O
Dearborn , Michigan
I'm pleased with the results of 'NuFinish' (used a whole 16oz bottle on the trailer!)... also been using it on the truck for several years, and it's very durable. I tried 'Ice' and a product by 3M (in a black bottle, forgot name)- not impressed... seemed to loose its shine and water bead quickly
finalcutjoe is offline   Reply With Quote
favorite wax lisa.bivens Cleaning, Stripping & Polishing 11 04-18-2008 05:56 AM
When to Wax woodedareas Cleaning, Stripping & Polishing 8 06-24-2007 11:25 PM
Glass Wax...if you REALLY want some~ InsideOut Cleaning, Stripping & Polishing 0 07-07-2006 01:51 AM
Wax after compounding????? Two-Dogs Cleaning, Stripping & Polishing 2 02-28-2006 09:28 PM
Wax Scott Hopkin Cleaning, Stripping & Polishing 10 05-11-2005 08:14 AM
