Old 10-12-2011, 04:57 AM   #15
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Griot's Paint Sealant... (8oz=5 times w/some left)
I've not found anything that looks better or lasts longer...
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-12-2011, 05:14 AM   #16
Foevrluvinit's Avatar
1986 34' Excella
Patrick AFB , Florida
Thank you both for your reply. I think I am going to make an offer today on the AS and maybe I'll be an Airstreamer again soon!
Foevrluvinit is offline   Reply With Quote
Old 10-12-2011, 12:10 PM   #17
Images: 18
Originally Posted by maccamper
I will be polishing for the first time this year and have already found out that P&S will not clearcoat a trailer that they don't polish.
It looks like I will be waxing over the polished aluminum, has anyone tried a good quality carnuba wax? Thanks.
Well good to know that I cant just get clear coat at P&S. It had occurred to me to have them do just that after we polish.The quote for them to do the 'works' on our 34' was between 6-9k dollars. Definitely not intrested in spending that. Now we will research doing the clear coat ourselves and if we dont find anything we will go with the carnuba wax. We are interested to see how your trailer turns out. Have you heard of Alodine 1001? It sounds like it would work but as yet, I haven't found anyone that has experience to share for airstream application.
yve79 is offline   Reply With Quote
Old 10-12-2011, 01:44 PM   #18
If you can spray paint, you can do the clear coat yourself.
Alodine, is not a good idea, since it contains an acid.
Old 10-12-2011, 04:22 PM   #19
Images: 18
Andy is the spray paint clear coat similar to factory plasti-coat? What is the brand and where can I get it?
Thanks for your help.
Old 10-12-2011, 05:45 PM   #20
casa3805's Avatar
Corpus Christi , Texas
Images: 41
Just ordered some. Appreciate the recommendation. Guess I will see what it can do for my old beat up rig...
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 10-13-2011, 01:37 PM   #21
The new type "clearcoat" replaces the old material.
However, the newest clearcoat, is a 2 part mixture.
It's only available from Airstream or an Airstream parts stocking dealer.
Old 10-13-2011, 02:41 PM   #22
Andy,
Since the new panels are pre-coated from Alcoa is it just the Service Center thats using the new clearcoat? Do they even have a booth to do the older ones?
I've got a 4" square thats lifted off just below the curbside upper teardrop, trying to figure out how to smooth it out and blend it in.
PFC
"Tahawus"
RLC
John Prine
Old 10-13-2011, 02:56 PM   #23
Andy,
Bob.
All you can do is use the spray can stuff from Airstream.
After it cures out, you can rub it with some white rubbing compound. That will help you blend it in as well as get rid of the over spray.
Be prepared however, that the edges of the old paint may "lift" when you apply the new paint.
Good luck.
Old 10-15-2011, 05:44 AM   #24
Bob.
Good luck.
Andy,
Lifting edges....thats exactly what happened the other day when I attempted to at least get it covered before our latest trip. I knew it was going to be a temporary fix, and I used a Krylon clear, but I was surprised that it lifted the edges so much. At least it's up top and kind'a out of sight, time for some trial and error.
PFC
"Tahawus"
RLC
John Prine
Old 10-15-2011, 07:00 AM   #25
Andy,
Bob.
The solvents from the new paint, work their way underneath the edges of the old paint, causing the lifting.
The longer it takes for the new paint to cure, the greater the lifting, especially with dissimilar paints.
Old 10-15-2011, 10:02 PM   #26
Bob.
Andy,
A few years ago I tried some Thompson's water based stainless paint and clear on some filiform. It's turned out to be surprisingly durable. If we get some warm weather I may prep and give that a try. Maybe it won't have such an aggressive reaction.
Thank's Andy
PFC
"Tahawus"
RLC
John Prine
favorite wax lisa.bivens Cleaning, Stripping & Polishing 11 04-18-2008 04:56 AM
When to Wax woodedareas Cleaning, Stripping & Polishing 8 06-24-2007 10:25 PM
Glass Wax...if you REALLY want some~ InsideOut Cleaning, Stripping & Polishing 0 07-07-2006 12:51 AM
Wax after compounding????? Two-Dogs Cleaning, Stripping & Polishing 2 02-28-2006 08:28 PM
Wax Scott Hopkin Cleaning, Stripping & Polishing 10 05-11-2005 07:14 AM
