Old 03-26-2011, 05:12 PM   #1
star kitty's Avatar
1967 20' Globetrotter
denver , Colorado
Exterior Paint Removal
Just out of curiosity, how hard is it to remove the paint on the exterior skin of an Airstream?
Did the surface need to be prepped by sanding before the application therefore degrading the aluminum surface? Is the removal similar, if not the same, for removing the clear coat? If so, what would you expect to find underneath?
There is an AS on Craigs in Phoenix that has been painted and my father and I were discussing this very issue.
How much work is in store to remove it and is there another reason (other than personal preference) one would paint the exterior?
Thank you!
star kitty is offline   Reply With Quote
Old 07-25-2011, 05:11 PM   #2
Sandy , Utah
I'm looking at a trailer with the same issue? Is it worth passing on or can this be removed easily? It's already flaking in some areas.
slimbrady is offline   Reply With Quote
Old 07-25-2011, 08:32 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
What's under the paint? Bondo?
It may need to be repainted.
Guess I'll pass.
Old 07-25-2011, 08:37 PM   #4
1978 Argosy 27
Lacey , Washington
Images: 8
Its and AS that wanted to secretly be an Argosy. smile
jjustice is offline   Reply With Quote
Old 07-30-2011, 02:19 PM   #5
Tallahassee , Florida
Dear star kitty,
I removed the clear coat with Jasco Paint and Epoxy Remover I purchased at Lowe's. It will damage plastic lenses and fixtures. Remove them or mask them to prevent damage.
If the Airstream has been sanded, primed and painted, you might consider having the paint redone with a high quality paint by a professional painter like Inland RV.
JimWeilhammer is offline   Reply With Quote
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 11:46 PM
Water Heater Removal Ag'71 Water Heaters, Filters & Pumps 3 02-21-2011 05:53 PM
Lens removal for orange running lights on 1973 model AirHome Lights - Interior & Exterior 6 02-07-2011 10:42 PM
'75 TW fresh tank removal 1 man Breadbug Fresh Water Systems 4 02-01-2011 08:31 PM
interior trim around door removal? Bill M. General Interior Topics 2 01-24-2011 09:25 AM
