I know it's not much, but when I get one more emblem finished, it makes our Sovereign look that much better.
This one was a real PITA to do. In retrospect, I probably should have masked the area around the emblem and sprayed the letters, then sand...what I did was handpaint the letters and sand, then I clearcoated. Oh well, it was fun and made the time go by, while I was on leave.
Here's the result. I still haven't painted the area above the "Land Yacht" part in light blue, because I need to get a punch set and redo the letters and numbers there.
BTW, I know the bottom part, under the "Land Yacht" is where my VIN is supposed to be (need to repunch that too), but what the heck are the letters and numbers above the "Land Yacht"?
__________________ SFC Frederic Lynes 1971 Sovereign International 2004 F-350 King Ranch EX-WBCCI # 8371 AIR # 8239
Ours in need of rehab as well, with peeling & faded paint. Have you redone your main emblems in the side of the AS? If so what paint did you use for those? What was your sanding technique used?
I did indeed redo the main side emblems, using the same Chrysler Intense Blue Pearl (in a spray can), Porsche Guards Red and I can't remember the name of the white, but it's pretty bright (I think it was Ford Oxford White). I masked off The red and white part and sprayed the blue first, then let it dry for the day. The next day I did the opposite and sprayed the red (mind you, this is on both sides). The final day I masked off the blue and red parts and sprayed the white. Once the white had dried, I carefully, with my fingernail, cleaned off the chrome "Airstream" script. The one thing I never did do, which I will probably get around to soon, was spray clear over the whole thing, but it still looks new two years later.
If you pull a search on my screen name, you'll find pics of the side emblems....I redid them in the summer of 2007, when I was at Ft. Huachuca, AZ and bored out of my mind (I was there for a three weeks school).
If you can't find them, let me know and I'll try to find them for you.
I'm intrigued by your work but am at a complete loss as to how you accomplished it. If you wouldn't mind, can you share some details? What did you actually sand? I'm thinking that you painted the area of the recessed letters (Airstream & Sovereign) and then sanded the top to remove the excess so that the paint only remained in the recessed area of the lettering. Is that right? But the surface looks pristine - not like it was sanded at all....
Laura, you're absolutely right, that's what I did...the trick is what you use to finish the surface. I started with 120 grit, then moved to 220 grit, then finished with a 320 grit buffing wheel on my Dremel. When I was done, I clearcoated with Krylon.
Fred,
Couldn't you also use a thin coat of vaseline over the main part of the plate? This is what I did for the letters on my International emblem. The white paint easily came off of the letters.
__________________ Sterling - 1972 Sovereign Intl (RB) Eddie - 2003 Ford Excursion (6.0L PSD) Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2 Airstream Life Contributor WBCCI 4CU #5661/AIR #5661
Thanks for the details... now I know what to tackle when I'm bored too! Though it won't happen soon with my list of to-do's.
Not sure if this was easier but for the letters, I painted by hand/striping brush, then wiped the top surface of the lettering off with a cotton rag holding my finger as flat as possible. This avoided having to sand the surface after painting.
Not the best photo but:
Tadd, Beth and the Shiny Turd (until she names it) Our blog
