01-03-2013, 07:31 PM
Hollis
, New Hampshire
Experience with Alodine?
In the 1963 Airstreams (and perhaps other years) the International trim had gold frames around the Airstream nameplates and ss# plates. Due to fading you won't see this till the plates are removed.
I'd really like to recreate this. I've tried numerous paints and "anodized look" paints...nothing comes close.
Today I tried using alodine and it didn't work. I prepped everything with alumiprep and scotchbrite but the alodine simply washed right off.
And then I noticed that the alodine worked on the cut edges that were exposed for the first time (see picture below) so I've come to the conclusion that it's not my solution or prep. Maybe something that has been anodized (which I am assuming was the original process) cannot be alodined?
Any suggestions?
Ok, the pictures not that great but it really did only "take" the alodine on the edge.
The frames
01-03-2013, 07:52 PM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Hi Shelly,
I don't think Alodine would give you the look you are going for even if it did convert the surface to an even gold color. It would wear off fairly quickly. You could give it a bath in Alodine for a few hours to see if it will convert the surface. Have you looked into having it anodized gold? Of course gold $$$ plating would be the best choice
Lance
01-03-2013, 08:01 PM
Hollis
, New Hampshire
Originally Posted by Top
Hi Shelly,
I was hoping I could clearcoat it and stop it from wearing off . Yeah I looked into anodizing it but it was $$$ and I didn't get a great vibe from the shop. I'll look into it again at a different place!
Gold plating ....very funny Top Might as well have the whole trailer done too!
01-03-2013, 08:10 PM
Always learning
1972 29' Ambassador
Central
You might try this place.
Waco Metal Finishing
If you need local support, I'm just down the road.
Lance
01-03-2013, 09:09 PM
1977 31' Sovereign
1989 34' Excella
Johnsburg
Alodine is a chemical process that reacts with the raw aluminum. Any pretreatment that leave the aluminum in the oxided state will prevent the alodine from working. Anodize convert the surface to completely oxidized and so prevents the alodine from reacting.
01-05-2013, 10:01 PM
Hollis
, New Hampshire
Hey Aerowood! Can I re-anodize without problems?
01-06-2013, 01:09 AM
2005 19' Safari
GLENDALE
, AZ
In the aerospace industry, we used Alodine to touch up scratches in the anodized coating on aluminum parts. Alodine was a temporary coating and was just used to protect the touched-up bare metal for a day or two until it could be painted. Alodine is soft and can be rubbed off, and the stuff we used didn't have much color in it.
Dye was used in the anodize solution so that people could see that the surface had been treated. Gold (dark yellow) dye was used most of the time, but I think I recall seeing blue, green and clear on some parts. The color used to vary a lot, but the shade is not necessarily an indication of the thickness of the anodized coating. We didn't inspect for shade, but only for the presence of color to indicate that the part had been anodized.
In addition, you can tell if the surface of a part is anodized by lightly touching it with volt-ohm-meter probes, with the meter set to measure resistance (Ohms). Bare aluminum is conductive and will indicate a direct short between the probes, while an anodized surface will show high resistance.
As an aside, gold plating isn't terribly expensive; but the process requires special equipment and some very toxic chemicals.
Have you considered gold leaf? This is gold in extremely thin sheets that is applied using a brush and static electricity. After it is applied, I think you can use clear lacquer to keep it in place, although I have not worked in this medium before. You can get gold leaf at hobby stores and other places, and it is sometimes used in making fine pastries (it is edible, though gold isn't actually digested). You may wish to investigate further to see if this would work for your application.
Also, I would look more into clear, gold-colored lacquer or paint, as this may be the least costly way to restore these frames. Antique and hobby shops may be able to provide leads to products that might work.
01-06-2013, 04:54 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
Wally's Gold Trailer is still down at Jackson Center. It is stored outdoors and the Gold Alodine has deteriorated badly. Alodine contains a transparent dye and most organic dyes degrade when exposed to the sun for long periods.
01-06-2013, 07:11 AM
Baltimore
, Maryland
Gold high gloss aerosol paint with a flat clear over it will give you virtually the same effect you seeking. I have used this technique on trailers of our era numerous times and it works very well.
01-06-2013, 09:58 AM
1971 21' Globetrotter
Arvada
Yes, but the original anodize will need to be removed first. I'm not sure if it can be done chemically, electronically, or mechanically. Generally we just remake the part.
01-17-2013, 03:41 PM
Baltimore
, Maryland
I think there may be some confusion between a anodize coating as found on the infamous Gold Trailer, belonging to Wally Byam and the gold frames found on Reinergirl's frames versus alodine coating which is used to prevent oxide on metals. Very similar sounding words, very similar color finish, very different use and longevity.
01-18-2013, 07:49 PM
Hollis
, New Hampshire
Franks right, my intention was to alodine to get the color and then clearcoat it.
The pieces were originally anodized however, anodizing is not very do-it-yourself friendly. And surprisingly expensive to have done.
01-18-2013, 08:05 PM
Baltimore
, Maryland
How true you are. I wrote up a proposal to Airstream to restore the Gold Trailer. The anodization stopped me dead in my proposal. It was a mere pipe dream. Gloss metallic spray bomb with flat clear will create a near close effect you seek. I have experimented with his extensively...
09-05-2014, 02:01 PM
2013 25' FB International
Liberty Corner
, New Jersey
I see that this is an old thread, but has anyone had experience with Alodine 1132 Touch-N-Prep Pen for "surface protection"?
09-06-2014, 04:09 AM
2005 19' Safari
GLENDALE
, AZ
When I was much younger and worked in a factory where they processed aluminum parts, they cleaned castings in acid baths, then used Alodine as a temporary protective coating to slow oxidation until the parts could be painted. The Alodine coating we used only lasted a day or two, and parts that weren't painted within 24 hours had to be returned to be cleaned again and recoated before painting.
Unless the Alodine you are asking about is much different from what we used to use, I would suspect that this product won't last long, if not followed by a more permanent treatment or coating.
By the way, Alodine used to come in colors. I know that it came in "clear"; but we didn't use it, because you couldn't visually tell if the part had been treated. We used "yellow", which was kind of golden in color.
09-06-2014, 06:22 AM
1994 30' Excella
Mississauga
, Ontario
If you are going to do a paint finish on small parts, why not use an acid-etch primer. It etches and primes the part in one step and is designed for use on aluminum. Then topcoat with whatever you want.
Al
Al and Jean
TAC ON-3
09-06-2014, 06:29 AM
1981 31' Excella II
New Market
, Alabama
Be careful with Alodine. It is very toxic.
Perry
09-06-2014, 06:33 AM
Liberty Corner
, New Jersey
I am waiting for more technical data, but it looks like a touch-up option to areas that are displaying the potential for corrosion.
