Old 02-04-2014, 07:03 AM   #1
arden_dean's Avatar
1986 34.5' Airstream 345
topeka , Kansas
Images: 26
diamond satin clear coat
has anyone tried this clear coat for bare metal?
Eastwood Diamond Clear Satin Set
“The world is a book and those who do not travel read only one page.” – St. Augustine
arden_dean is offline   Reply With Quote
Old 02-04-2014, 08:07 AM   #2
1981 31' Excella II
New Market , Alabama
No I have not tried it but I would talk to the manufacture about surface prep and how they deal with the oxide layer that aluminum forms that usually makes it hard for many coatings to stick without some sort of surface prep like alodine.
Perry
Old 02-04-2014, 08:11 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I did!
I installed all new interior aluminum and chose Diamond Brite to protect the new aluminum shine and surface. I talked with their Folks, and followed their instructions to the letter. It turned out horrible. I even had to replace one entire roof panel. In their response they said "oops!" we really did not want you to use MEK as a prep cleaner. It leaves a residue which will ruin the application. Yep....it did. On the new roof panel they gave me instructions as to how to use more of their prep cleaner. I followed those instruction and found out that the cleaner was an acid etch type which now converted the new panel to a cloudy surface. The Company refused to make good on any of it. They did, however, respond fast to all my questions and follow up....big help that was. All that work and expense pissed away.
Old 02-04-2014, 09:01 AM   #4
Experimenting with a clear coat can become real expensive.
Stay with what has been used for many years.
It works.
Old 02-04-2014, 10:00 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I am thinking that the old school clear coat used on early Airstreams was a clear lacquer, if I was going to clear an Airstream that is what I would use for several reasons, with repairability and film thickness being a couple of important reasons.
Applying any product over a polished surface is going to have adhesion issues. This just is.
Old 02-04-2014, 11:25 AM   #6
arden_dean's Avatar
topeka , Kansas
Images: 26
what works ?
what works ? The clear coat used by Airstream has changed over the years.
It works.
Old 02-04-2014, 12:18 PM   #7
I am not sure what the old plasticote was, but it certainly was not lacquer based.
Old 02-04-2014, 12:21 PM   #8
The new style clearcoat, CANNOT be applied in the field.
Airstream cannot apply it to the new metal.
The newest Plasticoat is a 2 part system, and is still available, since it's the only material that can be applied in the field.
Old 02-04-2014, 01:20 PM   #9
arden_dean's Avatar
topeka , Kansas
Images: 26
who sales it?
where can I buy it ?
Old 02-04-2014, 01:57 PM   #10
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
just curious but are you coating the interior skin or exterior?
truckasaurus is offline   Reply With Quote
Old 02-04-2014, 08:57 PM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I read somewhere it was a lacquer but I didn't proof it, I will submit to your expertise Andy!
Now I am curious as to what they did use.
Did AS start clearing in the 60 s?
I know my 72 was cleared, whatever it was, what little was left in the few areas where the sun didn't burn it off was very thin.
Old 02-05-2014, 07:25 AM   #12
arden_dean's Avatar
topeka , Kansas
Images: 26
My bad, exterior
I did the interior last year and ran out of time before camping season. This year I plan on doing the exterior, hopefully It will be ready before camping season.
Old 02-05-2014, 07:39 AM   #13
1981 31' Excella II
That acid etch is what preps the surface for the clear coat. If you want plastic over a mirror surface, I don't think you are going to get that. The only way a polish works is to keep it polished. I am not sure how Airstream did their old trailers. I expect it was a complicated expensive process and that is why they cheaped out and are using this factory coated junk on the new trailers. A good clear coat will etch the surface and that is why the finish looks kinda dull with the old clear coat. I expect it is the etch. I expect the old panels were dipped in an alodine solution rinsed dried then painted.
Perry
Old 02-05-2014, 09:06 AM   #14
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Some folks on the forum, myself included, have been using Nyalic® on corrosion repair areas with excellent results. It is regularly used in marine applications on aluminum bare metal for full boat coverage. I am unaware of anyone that has done their entire Airstream with it but I read somewhere that it had been done with good results. It has to be very carefully applied, but something to consider none-the-less.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Clear Coat Polishing Gojet Clearcoat, Exterior Paint & Trim 3 02-18-2012 12:25 PM
Removing the WBCC letter without doing damage to clear coat perryg114 Clearcoat, Exterior Paint & Trim 7 10-27-2011 11:45 AM
Taking Scratches out of the clear coat any ideas ksp2822 Clearcoat, Exterior Paint & Trim 3 09-28-2011 12:39 PM
Looking for clear coat refinishing wilkes711 Clearcoat, Exterior Paint & Trim 0 09-14-2011 11:59 PM
what clear coat product available deelind Ribs, Skins & Rivets 0 07-24-2011 05:54 PM
