Originally Posted by perryg114
The acid we are talking about is a weak acid that is consumed in producing a porous oxide layer that will allow the clear coat or paint to bond to the metal. Usually, it is something like hexavalent chromium (into a trailer and the edges and holes are not coated.
Andy how about finding out from Airstream how they coated their old trailers?
Perry
Perry.
Not everyone would pick a non abusive acid, simply because to them, acid is acid.
Airstream has used, in the past many years, several different types of clear coatings, that bond to bare aluminum.
They all lasted about 5 years or so, regardless of waxing or not.
Simple exposure to the sun, started the aging process.
Todays coating is not applied by Airstream.
Todays coating is even very tough against Aircraft stripper.
A relatively new panel's coating won't even be touched by Aircraft stripper.
