Old 12-06-2007, 02:47 PM   #1
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Details of painting Argosy with a roller.
Hello Argosy Owners;
Some of you have shown interest in following my project of roller painting my Argosy. The reason for another post is that during the process I have experimented a lot with technique and products used. While the roller and tipping of with brush did a great job, the tipping off was very time consuming. In the end, I have tried a SHUR-LINE Painter pad with unbelievable results, and this is what compels me to revise the last post.
When I have purchased my Argosy, I knew it had many issues which needed to be addressed. Galvanized end caps were badly pitted under the marker lights and some of the overlapped joints were showing some rust. Those areas were [spot sand blasted] using ducted hand held blaster with 110 PSI of compressed air. All rust was removed to the bare metal. Some small pits in the caps were sandblasted out as well. Bare spots were wiped with metal prep solution and coated with Marine Interlux # 353 Vinyl-Lux Primewash Base, which is an excellent two part Self Etching Metal Primer. Within an hour, Grey Marine Tex epoxy putty was applied to fill the low spots. The reason for the one hour timing of application is that you do not have to sand the primer before applying the putty. Since the primer is very thin, the sanding would remove the primer back to bare steel. Next day the putty was sanded smooth and flat with orbital sander.
Using an orbital DA with very light touch the entire end caps were sanded with a 220 grit sandpaper. Most of the primer on my unit was good, so I did not take it down to the bare metal. The roof area had some paint that was pitted and needed substantial sanding. Large, rivet free areas were sanded with 6” DA. Smaller spots were done with 3” DA. Area’s around the rivets were scuffed with Scotch Brite. All bare metal was coated with etching primer with a spray gun. One hour later first coat of Pettit # 3108 Off White Easypoxy was applied with a roller. In order to eliminate dry overlaps, the top section of the roof was tapped off just below the lap joints with blue 2” wide painters tape.
The first coat was thinned with 120/T10 Pettit thinner and I did not like the results. Entire painted surface was wet sanded before applying the second coat with 320 grit sandpaper. For the second paint coat I have used Penetrol. [Be sure it is for oil base paint not acrylic] Paint was cut by 15% and what a difference in ease of application and finish. Because of the heat factor to which the roof is exposed to, I have applied a third coat on the roof section after sanding the second coat.
The application procedure was as follows. Paint was applied with a Linzer Synthetic Lambskin ¼” nap roller. Covering about 4’ long area, on one half of the roof at the time, and re-rolling it dry once, ten minutes later. To smooth out the paint I have tipped it off immediately with a SHUR-LINE Painters Pad in one direction only. What a finish! The trick in smooth finish is the Penetrol which thins the paint and helps the paint to flow into a very smooth surface, and painters pad to level the paint. Altering from side to side every 4 feet, so that the paint does not dry up at any joints and make overlapping difficult. The next day, I have tapped of the end caps and followed the same procedure. Three coats were applied on end caps as well. Because of the roundness in end caps a smaller painter’s pad was used.
All glass was cleaned and tapped off leaving about 1/32 of exposed glass to provide a paint seal between the glass and glazing. Window and door gaskets were tapped off to prevent paint from sticking to gaskets. End caps were taped off on top joints but on newly painted side of the joints [be sure the paint has cured first]. Area above the beltline was tapped off on vertical overlaps into sections of each panel following clockwise direction. Beltline was also taped off. I have started in the rear panel applying paint in approximately 4 feet sections. I have re-rolled them dry and followed with the painters pad. Be sure to use a moderate and equal pressure on Painters Pad to spread the paint evenly. For large flat surfaces I have used a 7” Pad. Be sure to purchase couple of very small Painters Pads because you will need them around window frames and access doors.
Below the beltline I have used Pettit #3520 Grand Banks Beige cut with 15% Penetrol.
My beltline insert will be made from Formica cut into 1-1/16” strips. The rough backside will be painted with three coats of Pettit #3626 Burgundy Easypoxy as the Aluminum nameplates front and back of the trailer. Nameplates were glass beaded and recessed areas were painted burgundy color. The high outlines were sanded with a 600 grit paper and polished. The belly pan and trim will be burgundy as well.
The quantities of paint used were as follows. Because I did not stripped down to bare metal I have used two quarts of Primewash. Above beltline three coats on top plate and two coats on the sides took 1.5 gallons and 1.5 quarts of Penetrol. Sides below the beltline used up 3 quarts and 1 quart of Penetrol for two coats. My belly pan is last on the list to do, and I estimate that two quarts will do the job with less than a pint of Penetrol. So far I have used eight rollers and six Painters Pads not including three small detailing pads.
Retail pricing of paint is as follows;
2qts. of Primewash $ 65.98
1.5 gallon Pettit #3108 $170.08
3qts. Pettit #3520 $ 135.24
2qts. Pettit # 3626 $ 99.98
2qts of Penetrol $ 21.98
Total retail cost $ 493.26
My dealer cost was $295.95
Above does not include sandpaper tape rollers and other supplies and omitting enormous amount of time and sore aching arms. Despite it all I am pleased with the outcome knowing that my thorough job along with Marine epoxy finishes will provide me with many years of worry free service. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 12-06-2007, 06:28 PM   #2
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
Thanks for keeping us posted and for the details.
After talking with the painting team yesterday I think we will be using epoxy.
Karma coming your way.
em.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 12-06-2007, 08:19 PM   #3
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Boatdoc,
Thanks for the update. I'd be interested in photos when you get done. Love those Argosys.
Dave
Fyrzowt is offline   Reply With Quote
Old 03-29-2009, 06:32 PM   #4
woodysdad's Avatar
1968 22' Safari
1977 31' Sovereign
1977 Argosy 28
1977 28' Argosy 28
Mystic , Connecticut
Send a message via Skype™ to woodysdad
very informative thankyou, do you have any pics?
woodysdad is offline   Reply With Quote
Old 06-13-2009, 08:34 PM   #5
1976 24' Argosy 24
Milford , New Jersey
Say Boatdoc, how's that paint job holding up? It's been almost 2 years now. Any prolog or advice for us mere mortals. George
Gkiesel is offline   Reply With Quote
Old 06-14-2009, 04:40 AM   #6
boatdoc's Avatar
1973 Argosy 26
Hi George;
Our paint looks as the day it was finished. Arg was sitting outside all this time in our boat storage yard. Proper prep work had much to do with with the outcome. I have worked with epoxy paints for forty years this is why the decision to go with epoxy was done without any hesitation. In reference to your [us mere mortals] try to remember I am mortal as well. The only difference may be is in experience which I have gained by working with it. Knowledge can be obtained by asking questions, ability to do it will come with practice. You may surprise yourself if you try. Get a sheet of aluminum and start practicing on it in horizontal position. Flat surfaces anyone can paint with ease.
Because the business robs me of any free time, I have been unable to build the shelter for my Arg. However this past winter I was able to fabricate and weld [five] SS frames. The concrete pilings are in and the 28 pc. of 4'x8'x 0.032" painted aluminum have been all pre-formed on a metal brake and ready to be installed. Finished size will be 11'6'' x 31'. Front and the back will not be enclosed. I will post some pics when time comes to assemble it. Thanks, "Boatdoc"
Old 02-19-2010, 07:58 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
What photos?
I've been trying to find the photos you have posted of your work. All I can find is one of the frame. Looks like it is in your shop. Am I looking in the wrong place?
Old 02-19-2010, 10:21 AM   #8
boatdoc's Avatar
1973 Argosy 26
Hi TG Twinkie; If you are not finding more of my pic's please wait I will post some more soon as the three feet of the snow are gone. Thanks "Boatdoc"
Old 02-20-2010, 06:32 AM   #9
woodysdad's Avatar
1968 22' Safari
1977 31' Sovereign
1977 Argosy 28
1977 28' Argosy 28
here is a pic of my baby,I sprayed it after much prep, I'll send more later
ID:	96577   Click image for larger version
Argosy painted with a roller. boatdoc Clearcoat, Exterior Paint & Trim 32 03-21-2017 10:06 PM
Painting an Argosy. mrmossyone All Argosy Trailers 18 12-02-2007 07:42 PM
Painting exterior details - decal plates, bumper? Tin Lizzy Clearcoat, Exterior Paint & Trim 4 05-02-2006 06:42 PM
Painting a Argosy George Clearcoat, Exterior Paint & Trim 2 09-17-2004 05:09 PM
Painting an Argosy mcneon General Motorhome Topics 14 09-04-2003 07:36 AM
