Old 04-13-2004, 12:49 PM   #1
mtpalms's Avatar
1971 23' Safari
Joshua Tree , California
Desired: 4' of 3/4" blue trim
Our '71 Safari has a smoked shade on the back window, which is probably not a standard item, but it is there, it is useful, and removing it would require filling in the resulting screw holes, so it stays. At least for now anyways, as there are more important renovations that need our attention, like the fridge and the air conditioner.
It has a 3/4" trim piece ('beltline') across the center that used to be blue, but now it's sun-rot brown. I'd like to replace it, and I am hoping there is a member out there who has an extra 4' to spare - left over from one of those 50' rolls.
Thanks in advance.
mtpalms is offline   Reply With Quote
Old 04-14-2004, 11:38 AM   #2
mtpalms's Avatar
1971 23' Safari
C'mon guys, no one has "a square to spare"?
Please?
Old 04-14-2004, 12:05 PM   #3
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Where
What is it for, I am confused.
The AC or Fridge or something else.
Smily
smily is offline   Reply With Quote
Old 04-14-2004, 02:31 PM   #4
mtpalms's Avatar
1971 23' Safari
I was afraid there would be confusion about this, so I took a picture, but forgot to bring the picture disk to work so I could post it.
I need it for a smoked plexiglas sun shade on the back of my Safari over the bathroom window. The shade has a vinyl trim piece that used to be blue, but has turned brown from exposure to the sun. I need a 4' long 3/4" strip of blue vinyl and I hope that someone with a 1974 to 1977 model might have some laying around from a recent renovation. My tralier is pre-vinyl, so I won't ever need a 50 ft roll.
I will try to remember the disk tomorrow so I can post a picture.
Old 04-14-2004, 06:04 PM   #5
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
RE Blue trim
Please post a pic.. have some left over from doing our Tradewind.. Annie
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 04-14-2004, 08:22 PM   #6
zamboni's Avatar
vinyl sticker???
Would vinyl sticker material (like a bumper sticker is made of work)? You might be able to pick up a scrap from a local sign shop (Fastsigns) in almost any color...if they make you pay for it cut to a custom size...3/4" X 48", it should be less than $10.00. If this is not the type of product, sorry.
zamboni is offline   Reply With Quote
Old 04-15-2004, 09:38 AM   #7
mtpalms's Avatar
1971 23' Safari
Here's the shade:
Here's a detail. As you can see, it once was blue, but now is brownish. (Odd how the camera autofocused on the reflection instead of the trim piece )
Thanks for your patience everybody. I measured the width of the strip and it is 3/4"
Old 04-15-2004, 07:54 PM   #8
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Interesting, this is the first smoked window covering I have ever seen on the rear window of an Airstream.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 04-16-2004, 10:06 AM   #9
mtpalms's Avatar
1971 23' Safari
It doesn't look all that bad unless you look closely, and notice that it isn't proportional to the window. It does protect the pull-down blind from UV exposure though, and that is important out here in the desert. That, and removing it would leave a bunch of screw holes that would need to be filled, so it stays for awhile yet anyway.
Lower Trim Color on 2000 Excella Cracker Clearcoat, Exterior Paint & Trim 0 01-26-2004 07:04 AM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 12:10 PM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
