Old 11-07-2013, 08:10 PM   #1
Tom and Phyllis
Lucky Tom's Avatar
2009 23' FB Flying Cloud
Tuscaloosa , Alabama
Deep scratches in clear coat. 2009 Flying Cloud
When the clear coat gets a good scratch in it, do you polish over it with a wax or polish or reapply a touch-up type of clear coat?
Lucky Tom is offline   Reply With Quote
Old 11-08-2013, 04:14 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I treat it like a car and use clear coat touch up, then a bit of light rubbing compound to blend it in.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-08-2013, 07:35 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Apply the clear coat or you will soon have filiform corrosion all along the scratch if it is exposing unprotected aluminum. Use the finest bead of clear coat possible, even masking tape on the sides of the scratch to minimize the "scar".
Doug and Cheryl
Old 11-08-2013, 08:38 AM   #4
2008 27' Safari FB SE
Pfafftown , North Carolina
Glare Knockout
Has anyone tried the product "Glare Knockout" sold on the Airstream.com store? Seems it is recommended for removing scratches.
Thanks.
Susan
sunnygirl is offline   Reply With Quote
Old 11-08-2013, 09:42 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thanks.
Susan
It's for surface scratches, translation---all scratches are 'surface' scratches and this does nothing to remove anything but polishing 'swirls' or brush marks from washing, oxidation, water marks & berd poop.
If you can feel it with your fingernail it will need to be addressed with compound, wet sandpaper, clearcoat or a combination of methods recommended by those more adept than I.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-08-2013, 11:25 AM   #6
Bob,
Thanks for the information. Most of our scratches can't be felt with your fingernail.
Susan
Old 11-16-2013, 09:29 PM   #7
Road Geezer
Road Geezer's Avatar
2011 27' FB Flying Cloud
San Jose , California
Images: 34
I posted this question a week ago in a different forum and haven't gotten any replies. Seems like there's some good advice in this thread but I'd appreciate finding out specifically what products anyone used to fix their scratches before I go much further with my repair. My scratches are about 6 ft long and 1/4 to 1/2 wide.
"We just got back from a 10.5k trip across country. Somewhere along the way I picked up a couple long rub marks on the exterior aluminum siding. Whatever rubbed against the side didn't crease the aluminum, nor did it penetrate the plastic coating. It was almost as if a bicycle handle grip created the marks.
I've removed the residue from whatever rubbed my side, but I'm left with shallow scratches in the plastic coating, kinda like would be made by an abrasive stick. I tried Maguire's touch up car polish (non abrasive) and it helped a little, but did nothing to remove the scratches. I then tried wet sanding a small area with a 12,000--yes, 12,000, not 1,200--grit furniture finishing pad and I can tell that with enough rubbing I will eventually polish out the scratches. I just don't know if I'll cut thru the plastic, so I'm looking for any advice on alternatives before I expend all the elbow grease I'll have to with wet sanding."
Thanks for your help,
Paul
As far as I know, this is the oldest I've ever been.
Road Geezer is offline   Reply With Quote
Old 11-25-2013, 07:17 PM   #8
Road Geezer
Images: 34
Clear Coat Scratch Fix
So I tried a couple different approaches to hiding the scratches on our sides. Even 12,000 grit wet sanding left slightly clouded areas on the unblemished areas next to the scratches.
So I went to O'Reilly's auto store and found some clear coat repair liquid that seems to have worked pretty good. It goes on like touch up paint with a small brush. It completely filled the scratches so that they're almost invisible from many different angles in direct sunlight. There is a very small ridge where the coating sits on top of the surface; so while not perfect, it's a huge improvement over looking at the scratches. I don't know how well this stuff will stand up to sunlight and weather; stay tuned.
Here's a pic of the product I bought at O'Reilly's.
Paul
Old 09-12-2015, 11:00 PM   #9
1962 16' Bambi
Pendleton , Oregon
I have a deep gouge in my side pannel, curled the aluminum as it traveled along the side. Not through the skin but almost. Any ideas as to how to repair, short of a new pannel?
62BAMBI is offline   Reply With Quote
Old 09-12-2015, 11:15 PM   #10
Posting a photo will help answering your question.
Old 09-13-2015, 07:24 AM   #11
2016 30' Classic
Erie , Colorado
The Airstream store also sells clearcoat.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 02-10-2016, 05:20 AM   #12
wdh
2010 23' FB Flying Cloud
Fort Worth , Texas
I got hit by a gate as I was pulling out. Any ideas on how to fix these scratches?
wdh is offline   Reply With Quote
