Old 02-07-2011, 03:25 PM   #1
1992 35' Airstream 350
sault ste marie , Ontario
decal replacement
I have a 1992 350 le motorhome and need to remove and replace decals. whats the best way to do this?
queensville is offline   Reply With Quote
Old 02-07-2011, 04:04 PM   #2
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
You can get the decals themselves off with a heat gun. Then you have to contend with the glue that held the decals on. I was stripping mine to polish, so I used paint stripper to get the glue off. You might be able to get the glue off with alcohol so as not to harm the clear coat.
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 02-07-2011, 04:36 PM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Decals
Decals lift with lots of heat. I presume you have an aluminum unit so I will leave someone who has done it to give advice. F/g units don't like some of the exotic paint remover.
Dave
New Decal for her funkill Clearcoat, Exterior Paint & Trim 8 04-07-2011 07:58 AM
'77 Argosy entry door replacement Camp Argosy Motorhomes 7 02-02-2011 07:37 AM
Pls HELP Replacement of Deadbolt in Handle of '90 Elf1 Doors & Locks 8 01-28-2011 08:16 PM
A/C pan replacement Airhouse Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-28-2011 07:16 PM
Water Filter Sump Replacement elzavb Water Heaters, Filters & Pumps 1 01-11-2011 05:12 PM
