Old 05-20-2014, 03:51 PM   #1
Dickandvicki's Avatar
1991 29' Excella
Tulsa , Oklahoma
Confused.. Clear Coat Pealing
I have several large areas on the top of my '91 Excella where the clear coat has flacked/pealed off. I have been reading through all these threads and it sounds like a really big problem. I had hoped that I could find someone to just take off the old clear coat and spray on some new clear coat..
Is this really such a big problem to fix? I love my AS and want her pretty again..
Dickandvicki is offline   Reply With Quote
Old 05-20-2014, 03:56 PM   #2
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
It's not a big problem at all. The clear coat is easy to remove - here's a good thread: http://www.airforums.com/forums/f441...ml#post1456931 - there are many others.
The plot does thicken if you want a highly polished finish though. Very, very time consuming to do it yourself. Lots of threads about that also.
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 05-20-2014, 04:10 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
You have three options;
  • Ignore it and enjoy the APB (Airstream Pattern Baldness)
  • Pay to have it stripped and new clear coat sprayed on ($$$$)
  • Strip it and polish (time consuming to maintain)
I went with option one, eventually I will strip it and use something like Nevr-Dull to give it a polish.
Aaron
WBCCI #XXXX AIR #2495
Old 05-20-2014, 04:21 PM   #4
1991 29' Excella
Tulsa , Oklahoma
Thank you for your replies. This isn't something that I want to tackle myself. I live in Oklahoma and called a local AS restorer. They told me that they don't do this type of work any more (EPA Restrictions) and recommended a well known company out of Ohio Called P&S. I gave them a call and he indicated that it would cost between $5,500 and $7,500.. Yikes!
I have also heard of a man that has done exterior work on SOB's. Actually saw a vintage Scotty that he painted and it look beautiful. I thought I would talk to him and see if he could help me out.
Love your term Airstream Pattern Baldness!
Old 05-20-2014, 04:29 PM   #5
r carl's Avatar
Lin , Ne
I would try and talk to a few body shops in your area. They know how to spray clear coat. You would need to find one that could accommodate your camper. You just never know......
Old 05-20-2014, 07:05 PM   #6
1986 31' Sovereign
Miami , Florida
Automotive clear coat will not work. The aluminum expands and contracts far more than steel.
The product that is applied by P&S and other Airstream specialists is Plasticoat. Unfortunately, stripping and replasticoating is labor intensive and pricey. A good refinishing will last 5 to 7 years depending on climate and locale.
I used Citristrip to remove the failed Plasticoat on both end caps and above the drip line and then polished with Meguiars aluminum polish. Looks fine for now.
Sooner or later I will pony up the big bucks to have it done properly.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-20-2014, 07:09 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Check with P&S trailer. One of their representatives at the Florida state rally said that it is relatively inexpensive to have them strip the clear coat and re apply. He also said it gets very expensive if it is allowed to go long enough to need to polish. His recommendation was to strip and recoat every 10 years.
Old 05-20-2014, 07:39 PM   #8
r carl's Avatar
Lin , Ne
Mike
You must use the correct clear coat, not the one for base coat-clear coat.
Old 05-20-2014, 07:45 PM   #9
1991 29' Excella
Tulsa , Oklahoma
I'll take pictures and send to P&S, but after talking to them it sounds like they are out of my price range at least for now. Thanks for all the information. At least now I have an idea of what needs to be done.. Geeze, I thought this would be fairly simple and not quite so expensive...
Old 05-20-2014, 07:57 PM   #10
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I don't know for sure about the clear, but as a person who has painted a lot of aluminum with color, I don't think the problem is so much with an automotive clear coat so much as it is with the inability to sand the soon to be clear coated bare aluminum.
Paint needs " tooth" to stick like it should.
I could make an automotive clear stick, but but I don't know what it would look like.. This is something I would need to do a bit of research on.
That said, depending on your time frame, I have a 65 foot booth in Little Rock...
Old 05-20-2014, 09:53 PM   #11
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Check out Nyalic. Go to the web site and actually call them. They have 2 Airstreams renovated and sprayed with Nyalic in Australia. I use the product as a touch up repair on newer Airstreams--Alcoa baked on clear coat (most posts located in thread, "corrosion problems with new Airstreams"). The product is a polymer resin. Works on bare AL in the marine environment, Or as a clearcoat over painted steel, etc. Unaffected by salt, UV, will not breakdown like plastic oat, acrylics or lacquers.
Howard L. is offline   Reply With Quote
Old 05-25-2014, 10:35 PM   #12
2012 16' Sport
Prince George , British Columbia
Howard
I went to the website for Nyalic and see that they have a few versions of the product. I am wondering if you used the aerosol product for the touch up repairs on the airstreams?
Keith
Keith and Sue in PG is offline   Reply With Quote
Old 05-26-2014, 06:22 AM   #13
Dwight's Avatar
1999 34' Excella
Joshua , Texas
If the clear coat is only on the top areas....usually the end caps are the worse....then you can just do the end caps or just recoat from the beltline up and save a ton of money.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 05-26-2014, 08:18 AM   #14
Pat Conway's Avatar
On our '88 the vinyl center stripe was peeling off and very unsightly, in addition to the clear coat peeling off (it had been refinished from the belt line up in 2002). I made the mistake of dropping the trailer off at an RV repair facility that thought they could do the work, kept it for five months and scarred it up badly. They had no clue what they were doing. I must blame myself also for not doing my homework here too. Anyway, I took it to P&S and had to spring for the full polishing and re plasticoating. This included extra hours of polishing to buff out the scarring. Am convinced you really have to know what you are doing and have the facility to do the work. Am about to pick it up in a few days. From the pics they did a beautiful job. I only wish I had taken it to them in the beginning, No substitute for 30 years experience. Hope this helps in your decision, Pat
Sun City Center, FL
1988 25' Excella
Pat Conway is offline   Reply With Quote
Clear coat pealing Brian Bailey Roof 6 05-13-2014 09:53 PM
clear coat remove & polish? confused tempest2 Clearcoat, Exterior Paint & Trim 8 07-13-2010 12:39 PM
Galley Sink Paint Pealing Off Cracker Sinks, Showers & Toilets 1 04-21-2008 05:47 PM
Full Timing in Trlr w\pealing Clearcoat route66 Full-Timing 4 11-25-2005 03:50 AM
vinyl pealing off cabinet doors ?????? vtjoesmith Cabinets, Counter Tops & Furnishings 0 11-20-2003 08:09 PM
