Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 04-12-2008, 07:22 PM   #1
Darrell Root
Darrell Root's Avatar
Profile:  2004 28' International CCD
Camarillo , California
Collinite Insulator Wax
Has any body used this wax?-I waxed a panel about a month ago holding up and beading well-has mold shedding properties,and I'm hoping filiform slowdown.
Darrell Root is offline   Reply With Quote
Old 04-12-2008, 08:16 PM   #2
RIstream'n
RIstream'n's Avatar
Profile:  2008 27' Safari FB SE
Cumberland , RI
I used this wax to orbital buff my motorhome when I had it. It worked great!! I love the stuff. I haven't tried it on my AS. I assume it will be the same. The stuff is very tough but easy to work with.
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
WBCCI #1199 - AIR #23847
NEU
LIFE IS GOOD
RIstream'n is offline   Reply With Quote
Old 04-12-2008, 08:19 PM   #3
2airishuman
2airishuman's Avatar
Profile:
hi darrel
the c-nite products seem to be popular with boaters and the fiberglass/gelcoat crowd.
i've used the insulator wax product on the truck/shell twice, last year.
it goes on/off very easy in warm weather, as do most liquid carnauba wax products...
a minimum of wax residue (during removal) and a nice shine and average durability, about 2-4 month, with 2 coats.
it contains naptha compounds and from the sweet smell i suspect it is benzene...
which is a significant carcinogen, so good ventilation is very important, also GLOVES
because of this solvent base i'd be reluctant to use it on the alcoa clearcoat on our 'streams.
while any quality wax may help prevent/delay the filiform corrosion issue,
caranuba waxes evaporate quickly outside and don't alter existing corrosion.
for these reason i favor using synthetic polymer sealants which generally last longer and have safer product profiles...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 04-12-2008, 10:00 PM   #4
Silverwanabe
Profile:  1967 26' Overlander
Winston Salem , North Carolina
Collinite Insulator Wax,
What is it and who sells it?
Never heard of this brand.
Greg
Winston Salem, NC
WBCCI 5218,
1967 Overlander International.
FTC 15771
1979 Avion 30ft rear bath
Silverwanabe is online now   Reply With Quote
Old 04-13-2008, 11:24 AM   #5
RIstream'n
RIstream'n's Avatar
Cumberland , RI
It's used by power companies and you can find it online. There are certain harware and marine stores that carry it as well. Just google it and you'll find it.
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
NEU
LIFE IS GOOD
Old 04-13-2008, 11:25 AM   #6
RIstream'n
RIstream'n's Avatar
Cumberland , RI
Go to nealsharbor.com
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
NEU
LIFE IS GOOD
Old 04-13-2008, 11:27 AM   #7
RIstream'n
RIstream'n's Avatar
Cumberland , RI
Collinite 850 is a metal wax. Here's their description:
The easy to use liquid metal wax cleans and protects chrome, aluminum, copper, brass and stainless steel in one easy step. Will safely remove rust and salt deposits while protecting marine fittings/accessories and car, truck, and motorcycle metal finishes. Contains neither strong acid, nor harsh alkali.
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
NEU
LIFE IS GOOD
Old 04-13-2008, 11:28 AM   #8
RIstream'n
RIstream'n's Avatar
Cumberland , RI
Go here:
Neal's Harbor: Collinite #850 Metal Wax
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
NEU
LIFE IS GOOD
Old 04-13-2008, 11:30 AM   #9
RIstream'n
RIstream'n's Avatar
Cumberland , RI
Here's the entire wax page:
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
NEU
LIFE IS GOOD
Old 04-13-2008, 11:32 AM   #10
RIstream'n
RIstream'n's Avatar
Cumberland , RI
Originally Posted by 2airishuman
hi darrel
cheers
2air'
Hey 2air, Here's the description of the insulator wax. If it's good for airplanes and power lines why not AS's?
This heavy duty liquid wax was originally developed for use by electric power companies for protection against high voltage power failure, fires and explosions. It's primary use is on the finishes of automobiles, trucks, buses and airplanes where durability, high gloss and lasting protection are paramount. An excellent choice for fleet applications and very easy to use--requires minimum rubbing or buffing. Clear coat safe. The favorite of professional detailers throughout New England. Apply by hand or machine with long lasting results.
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
NEU
LIFE IS GOOD
Old 04-13-2008, 11:36 AM   #11
RIstream'n
RIstream'n's Avatar
Cumberland , RI
Also it's clearcoat safe so why not?????
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
NEU
LIFE IS GOOD
Old 04-13-2008, 12:01 PM   #12
Darrell Root
collinite.com
The MSDS is posted on the collinite web page- yes to naptha compounds no to benzines- but most good automotive waxes have solvents including Walbernize super seal. oddly enough I found this wax at Harbor Freight $12.95-researched it and tried it,liked it--Darrell
Old 04-13-2008, 12:04 PM   #13
RIstream'n
RIstream'n's Avatar
Cumberland , RI
It worked well for me Darrell.
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
NEU
LIFE IS GOOD
Old 04-13-2008, 01:16 PM   #14
2airishuman
Profile:
i find the entire 'power line thing' a funny story...
and have never seen a lineman waxing insulators.
we've got some real linemen here, maybe they can tell us about waxing insulators...
naptha is used generically as a term for a subset of petrol solvents and USUALLY contains moderate amts of benzene.
regardless the product has a very HIGH SOLVENT content, which is why it's so liquid/creamy in texture.
please wear gloves with this stuff and be careful with ventilation.
comparisons to walb' are fine but walb' is a horrible product to use on newer 'streams, imo.
and c-nite is NON abrasive, which is an IMPROVEMENT over walb'...
folks should try lots of brands and decide 4 themselves, there are loads of brands that someone will like.
Originally Posted by Darrell Root
Has any body used this wax?...
the original question asking about use...
i've described my c-nite experience, it doesn't last long enough to make my top shelf of detailing supplies...
YMMV
2air'
What's new in Trailer Wax??? IrishRover2 Cleaning, Stripping & Polishing 0 11-06-2007 02:57 PM
When to Wax woodedareas Cleaning, Stripping & Polishing 8 06-24-2007 11:25 PM
Wax ring???? retrocats Sinks, Showers & Toilets 20 04-24-2007 09:02 PM
Wax Scott Hopkin Cleaning, Stripping & Polishing 10 05-11-2005 08:14 AM
Glass Wax InsideOut Cleaning, Stripping & Polishing 21 09-01-2003 03:31 PM
