Old 02-22-2011, 03:34 PM   #1
1980 Excella II
glh101282's Avatar
1980 31' Excella II
Los Alamos , New Mexico
Coated Aluminum
I am looking for a newer Airstream. Having had to pay for painting an Airstream already I am not looking forward to doing it again. I have heard and read a lot of positive comments in the Forum about the new coated aluminum from the aluminum supplier. Since I am looking for a 31 foot Excella/Classic around 10-15 years old, I understand that I am boarderline for getting an Airstream with the newer skin. Anyone know exactly what year Airstream began using the supplier coated aluminum for the skin?
glh101282 is offline   Reply With Quote
Old 02-22-2011, 03:44 PM   #2
_
it would appear that 1999-2000 was the change over year...
with trailer serial numbers (last 6 of the vin) AFTER 512600 having the new stuff.
and i find these 2 older threads especially funny given the C problems of recent years...
http://www.airforums.com/forums/f196...html#post24103
(post #5 above)
http://www.airforums.com/forums/f381...tml#post164044
((posts #6 and #8 and #11 above))
cheers
2air'
Old 02-22-2011, 10:17 PM   #3
1980 Excella II
glh101282's Avatar
1980 31' Excella II
Thanks for your reply. The info really nails down when the changeover happened. Now I just need to find a trailer.
Old 02-23-2011, 03:02 AM   #4
Baltimore , Maryland
What Airstream did you paint? Airstreams are not painted and doing so kills the value in most cases. Did you paint an Argosy?
The finish on the newer aluminum is not a forever finish. There are people with newer rigs than the years you are looking at with clear coat failure already. Just know it is not the end all system.
Old 02-24-2011, 08:01 PM   #5
1980 Excella II
glh101282's Avatar
1980 31' Excella II
Paint
I painted a 1980 Excella 31'. I live in New Mexico and the sun/ultraviolet rays shortens paint/coating/aluminum life a lot. The trailer is stored outside, thus the reason for the short 10 year life of the paint that was put on the Excella that I am replacing. C&G trailer in Bellflower CA did the paint job. The aluminum panels on the 1980 trailer were judged to be too blackened/pitted/oxidized to re-apply the clear coat and have it look good. The color used was reported to be 2000 Corvette silver.
I have seen other posting in the Forum that detail the problem that owners are having with the <10 year old Airstreams. I was thinking of getting a 2000 or newer Airstream because of the newer floorplan, wider body, and "trouble free" exterior. I guess that idea has been blown apart and I may just settle on a less expensive 1995 to 2000 wide body and figure on recoating every few years with the money that I saved.
I have owned Airstreams for more than 30 years so do not think that I would feel "right" in something else. Being 6'4" I have gotten used to ducking, taking showers in the tucked position, and dodging open overhead cabinet doors. More than fixing the aluminum I wish Airstream would bring back the troubadour doors.
Old 02-24-2011, 08:44 PM   #6
_
glh'
a/s HAS painted trailers and mohos made from aluminum.
bigAl has a 94 that's painted and it looks fantastic.
my 70s moho was painted and looked BETTER than new.
perhaps u've seen these threads...
http://www.airforums.com/forums/f381...ior-24469.html
http://www.airforums.com/forums/f474...nish-3191.html
http://www.airforums.com/forums/f474...tml#post515384
while the older (and current) plastiKote has a shorter life, the newer alcoa finish is NOT replaceable...
so pick your poison.
another option is stripping a new unit and polishing.
the newer/harder alloy skin will polish fine
and corrode more slowly than traditional older skins (and without filiform corrosion)
so depending on exposure, wax/sealant and so on, applying plastiKote may not be needed...
http://www.airforums.com/forums/f161...tml#post236828
for ease of use, simple care and camping without the hassle of maintaining...
silver paint (or other colors) is a reasonable option.
cheers
2air'
Old 02-24-2011, 10:38 PM   #7
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
My 77 was painted in 1990 for the same reasons glh's was and it has held up pretty good. A little touch up every 5 years or so helps.
4RXLA is offline   Reply With Quote
Is there anything wrong with this polishing? poezlaw Cleaning, Stripping & Polishing 18 02-06-2012 03:35 PM
Aluminum Trim for Plywood Walls Motochi Upholstery, Blinds, Walls & Interior Finishes 7 02-06-2011 09:33 AM
Aluminum Water Hose Al - K4GLU Fresh Water Systems 14 02-05-2011 05:47 AM
Replacing Steel Wheels with Aluminum crookedroad Wheels, Hubs & Bearings 8 02-03-2011 11:27 AM
