Old 04-27-2005, 04:21 PM   #1
Steve Heywood's Avatar
1997 30' Excella
Waddell , Arizona
Images: 13
Clearcoat Touchup??
When the previous owner of my 97 Excella removed his WCBBI numbers the clearcoat came off with them.
So my question is, how do I reapply the clearcoat to the areas where the numbers used to be?
Steve Heywood
Waddell, AZ
1999 19' Bambi (SOLD)
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 04-27-2005, 07:21 PM   #2
New Borockton , Alabama
Images: 21
Steve,
It's not easily done. Airstream dealers sell an aerosol can of clear coat touch up but I don't think it's much different than acrylic you can buy anywhere and it's won't look the same. It's better then nothing and will help the area from spreading. One thing you could do is join the WBCCI and cover most of the area with your own numbers!
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 04-27-2005, 08:30 PM   #3
eubank's Avatar
1967 30' Sovereign
Bosque Farms , New Mexico
Hey, check with WBCCI to see if the old numbers are still available! The barely visible outlines of our numbers were still there on our rig, so we inquired and got the same.
Lynn
WBCCI 21043
Old 04-27-2005, 09:10 PM   #4
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
I had the same problem, When I joined WBCCI the old numbers were 3836 so I requested 13836 to be my new numbers,And they were available so everything worked out well,
scf31 is offline   Reply With Quote
Stripping...Clearcoat that is! InsideOut Cleaning, Stripping & Polishing 19 07-12-2003 08:59 PM
Something other than clearcoat? dapalks Cleaning, Stripping & Polishing 16 03-01-2003 01:33 PM
Washing/waxing "new" clearcoat Kistler 2002 - 2005 International 13 11-21-2002 10:27 AM
Plasticoat vs. Clearcoat spray...?? HappyChi Clearcoat, Exterior Paint & Trim 9 08-12-2002 07:13 PM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 08:01 AM
