Old 04-09-2013, 01:49 PM   #1
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Clearcoat touchup
I imagine this has been covered, and recovered, but bear with me. I see in the Airstream.com website, they have a clearcoat "Touchup pencil" .....Have any of you used it,and what have been the results?
I've got a couple of small spaces, (less than an inch) that I'm starting to see a bit of corrosion. I've got that stopped with Corrosion X, but what's the best way to seal it?
Thanks for you help.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 04-09-2013, 01:54 PM   #2
dznf0g's Avatar
Oswego , Illinois
I've used it. It's as good as any other TU paint I've used.
-Rich-
Old 04-09-2013, 02:01 PM   #3
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I use automotive clear coat touch up. Spray can and touch up bottle with brush. Cleared my wheels and any thing else on the trailer I thought might show corrosion.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 04-10-2013, 08:26 AM   #4
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Thanks, both of you!
Larry
Old 04-10-2013, 09:04 AM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I have used it, and like it. It has very fine tip (push it against the surface to release the clear coat) to touch up tiny nicks, or you can spread it quite wide. A touch-up brush would leave a wider swath, it that's what you need.
doug k
Old 04-10-2013, 10:50 AM   #6
2010 27' FB Classic
N/A , Texas
I will also be looking for the clear coat touch up. I've used the pen AS sells and it is fine, but now mine is all dried up. I'll probably check out some local auto parts stores and dealerships for the pen. I think someone mentioned a while back that they found it at a Ford dealership.
I guess if I needed other stuff from JC I would just have them throw a clearcoat pen in the box too.
Old 04-10-2013, 12:00 PM   #7
dznf0g's Avatar
Oswego , Illinois
Just a tip offered for any of the bottles of TU paint with a brush. Most have a blunt cut bristle end. I have found if I clean off the new brush with appropriate solvent and carefully trim the end to a tapered angle cut, I have much better control of the paint application. FWIW.
-Rich-
Old 04-10-2013, 01:15 PM   #8
2010 27' FB Classic
N/A , Texas
Thanks Rich!
Old 06-14-2016, 06:39 AM   #9
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I have just had the pen delivered. I have spot over entry light and a few small on the roof. On the roof the largest size 2x5" the edges around it is not frayed, or peeling. Do I just fill in the area with the pen?
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
