Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 07-01-2003, 01:44 PM   #1
mcostanzo
mcostanzo's Avatar
Profile:
Clearcoat scratch removal
Washed the exterior last night for the first time since our last trip and discovered that scratches in the clearcoat up high on the roadside. Tree branches is my guess. These appear to be superficial . . . not all the way through the clearcoat. Does anyone have a recommendation for a product to use? Is a good cleaner wax like McGuiars (sp?) OK, or is there something better.
Mike
mcostanzo is offline   Reply With Quote
Old 07-01-2003, 02:35 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Airstream recommends Walbernize products. Try are avaliable either through Airstream or at AirstreamDreams.com
We don't use it because we have stripp-ed our clearcoat and are in the process of polishing it, but have seen the results on newer trailers and they look great! Some folks here can probably give better first hand experience with it...
Shari
InsideOut is online now   Reply With Quote
Old 07-01-2003, 03:54 PM   #3
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Re: Clearcoat scratch removal
Mike
Mike,
Use the Walbernize Super Seal product on your vintage of trailer. I have had a few of those marks and the Super Seal pretty much made them disappear. Keep in mind though that if the finish is scratched the Super Seal will not repair these. It just hides them.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 07-01-2003, 10:28 PM   #4
mcostanzo
mcostanzo's Avatar
Profile:
OK Walbernize it is!
Thanks for the recommendation. I'll order it and check it out.
Mike
plastic beads for clearcoat removal? john hd Cleaning, Stripping & Polishing 22 04-20-2008 12:30 PM
Which clearcoat? Bob Thompson Clearcoat, Exterior Paint & Trim 13 05-27-2004 07:36 PM
Clearcoat choice? TomD32 Clearcoat, Exterior Paint & Trim 4 09-23-2003 05:16 PM
'92 paint vs. clearcoat fangthorpe Clearcoat, Exterior Paint & Trim 1 06-22-2003 11:23 PM
Fixing a scratch on a brushed finish? acwdgw Cleaning, Stripping & Polishing 3 10-22-2002 02:27 PM
