Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 10-12-2009, 11:12 PM   #1
Profile:  1972 23' Safari
Tallassee , Alabama
Clearcoat Rejuvenation
I think our 72 AS spent a good amount of time indoors as the finish is still in pretty good shape. There are a few scratches in it but for now I am content to leave them alone.
My problem is that there are hand prints all over the areas where I have been working. In particular they are around the windows and the marker lights.
The hand prints don't seem to want to come off. I have tried several mild cleaners and they do nothing. I tried a little cleaner / car wax on it and it made some of the prints less obvious but it didn't remove them.
I have been reluctant to try anything more aggressive for fear of actually removing the coating.
We have had it on the road for the last month after 2 years of restoring it so I am not motivated to do anything dramatic to the finish at this time.
Tom
Tom Bray is offline   Reply With Quote
Old 10-12-2009, 11:36 PM   #2
2airishuman's Avatar
Profile:
hi tom
the 70s have plasticoat or plasti kote.
the original walb' product was intended for THAT coating...
see post #13 and #27 and beyond in this thread...
Order Walbernize?
and here
How to Polish?
looks like 'superseal' is the first choice, with cleaner, polish n glaze for naked skin streams...
because the older plasticoat was soft and HIGHER in plasticizers...
a modern 'vinyl spray' might also be useful, at least it will be SAFE on the old coating.
vinylex made by the lexol folks is a good example, but ANY of the older style vinyl sprays may work.
_________________
the "hand prints" seen may actually be residual SOLVENTS or grease/oil stains...
IF they've soaked INTO the old finish it's possible they will be visible till it peels...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-14-2009, 10:41 PM   #3
Tallassee , Alabama
Well, I tried some automotive plastic cleaner on it. The part in good shape looks really nice. Where I rubbed it a bit, I think the plastic got rubbed through since it has a different sheen to it. So the hand prints remain.
I will wait until I am ready to really address this and probably remove the old coating and put something else on in its place.
Old 10-14-2009, 10:58 PM   #4
Profile:
IF u rubbed through the coating, there should be gray or black alum on the rag...
just t b clear my suggestion is NOT a plastic cleaner/polish
but a vinyl DRESSING.
this may not help, but they have ZERO abrasives.
plasti kote is available to re apply.
it's not the same as the 70s stuff but close enough.
cheers
2air'
Clearcoat? How do I even tell I have it? TMiller Cleaning, Stripping & Polishing 14 08-25-2008 05:14 PM
clearcoat or not? air66stream Clearcoat, Exterior Paint & Trim 4 02-06-2008 02:00 PM
Clearcoat rnielsen Member Introductions 3 01-21-2007 06:59 PM
Clearcoat gone rama777 Cleaning, Stripping & Polishing 1 11-04-2006 08:19 PM
Which clearcoat? Bob Thompson Clearcoat, Exterior Paint & Trim 13 05-27-2004 07:36 PM
