Old 12-07-2010, 05:36 PM   #1
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Clearcoat or not?
Is there any way to tell if the clearcoat has been stripped from the exterior already?
If it has, is there something that I should to to protect the exterior in any way?
If it hasn't should I go ahead and strip it and put something else on there.. or more clearcoat?
DanielB is offline   Reply With Quote
Old 12-07-2010, 08:22 PM   #2
Ottawa , ON
I think that on your trailer it should be fairly obvious if it has NOT been done. On the photo below, you can see a few darker spots on the roof of my '74 and this is where the old CC has not come off.
In other words, you can see that mine has not been stripped.
Once you have stripped your TT, I think it should be carefully washed and waxed with something, Walbernize or better, once or twice a year, otherwise you will get the natural corrosion taking over.
A highly polished surface should probably been polished more frequently, to keep the high level of shine.
Old 12-07-2010, 10:18 PM   #3
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Melody Ranch says to get some tooth paste and rub it in a few places and if it turns blackish then the clearcoat is gone. The age of yours---people in the know say that the clearcoat has faded and burned off starting with the roof. and then on from there.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Clearcoat? How do I even tell I have it? TMiller Cleaning, Stripping & Polishing 14 08-25-2008 04:14 PM
Clearcoat Gone!!! evelitalian Cleaning, Stripping & Polishing 27 03-15-2008 03:08 PM
clearcoat or not? air66stream Clearcoat, Exterior Paint & Trim 4 02-06-2008 01:00 PM
Clearcoat gone rama777 Cleaning, Stripping & Polishing 1 11-04-2006 07:19 PM
Which clearcoat? Bob Thompson Clearcoat, Exterior Paint & Trim 13 05-27-2004 06:36 PM
