Peter...I have stripped the clearcoat on two Airstreams...a "60" and "78". Used Removal 220 on both. Have also tried more caustic products from automotive supply stores...Aircraft Stripper. The Removal 220 is the one to use in my book. It is biodegradable, easy to use (brush on, hose off). For awhile it was hard to find. I believe VTS is carrying it. If you use Removal 220, don't let it sit and dry out. I've found that it starts working right away and can be hosed off in an hour or so. Some have left it on overnight but I wouldn't advise that. You'll be amazed at the results, and your AS will look pretty good. But of course most of us can't stop there...polishing could be in your future as well.
Cheers....Bob
