10-09-2014, 08:55 PM
#41
1971 23' Safari
Nashville
, Tennessee
Originally Posted by teebs32
Here is a pick of the first pass of f9 on mine
Very nice !
I couldn’t fix your brakes, so I made your horn louder…..
10-14-2014, 07:58 AM
#42
1971 23' Safari
Nashville
, Tennessee
So can I compound buff with a random orbital polisher ? it will be my first pass of polish Nuvite G6 …..
Cable Porter #7336
10-14-2014, 11:15 AM
#43
1977 31' Sovereign
mansfield
, Ohio
I don't think you will hurt anything with trying it .. If it doesn't do the job then I would switch to a rotary
10-14-2014, 11:56 AM
#44
1971 23' Safari
Nashville
, Tennessee
It does spin ....
10-14-2014, 02:47 PM
#45
1977 31' Sovereign
mansfield
, Ohio
Yes but .. type of buffer usually works best when holding it flat to the surface . When I'm polishing I hold the buffer at an angle... Around 30 degrees. That has been working best for me . They also recommend using a twisted wool pad not a foam pad . Foam is good for paint . Bare metal not so much.
10-15-2014, 02:49 PM
#46
1971 23' Safari
Nashville
, Tennessee
I was reading the booklet I got with my Nuvite Polish and it says not to let rain dry on it or it creates hard to remove spots. I wish I could garage it but I can't , it is going to sit outside , am I wasting my time ?
10-15-2014, 07:44 PM
#47
1977 31' Sovereign
mansfield
, Ohio
It will to some extent but the more you polish the smoother the aluminum gets and the longer the shine will last . Once completely polished with a cyclo and nuvite s you may have to redo with s once a year . Like waxing a car .
10-20-2014, 03:40 PM
#48
1971 23' Safari
Nashville
, Tennessee
My mineral spirits seem to only cloud up my work , do I have the wrong kind ?
10-20-2014, 04:20 PM
#49
1977 31' Sovereign
mansfield
, Ohio
Should be just a residue.. it will wipe off with a clean dry cloth or wait until your done working and wash it off with a mild soap ... I put mine in a spay bottle and spray it on then wipe off... What you've done so far looks great. Did you try the random orbit ?? If so how did it work ? I the dewalt buffer in pic did you make a switch?
10-20-2014, 04:25 PM
#50
1971 23' Safari
Nashville
, Tennessee
I Dewalted , I want to find a pad for the RO Cable Porter but have not looked yet. I just wanted to get started and knew that was the way to go. I am taking about 3 or 4 applications of the G6 to get it shinning , I wonder if I need a more aggressive grade of the Nuvite ?
10-20-2014, 04:56 PM
#51
1971 23' Safari
Nashville
, Tennessee
Clearcoat
The front skin was the toughest to get shining , it appeared to have more mill marks than the rest of the trailer ; it was also the hardest to strip. It took about 7 applications of G6 to shine. The sides are easier , they are taking about 4 to get shiny. Running wool pads and cleaning with the tooth spur when shiny. Hitting around 1500 RPM and going very slow.
The bottom skin has 4 applications , the top small section has 2.
10-20-2014, 09:30 PM
#52
1977 31' Sovereign
mansfield
, Ohio
Yea... That's why I went with f9. I to started with g6. Wasn't getting the results I was expecting without several passes. The f9 works a lot faster. I agree that the upper corners of the skin seems harder to shine than the rest . Looking good though. I'm waiting till spring to do the last polish with s and buying a cyclo I don't want winter weather to ruin my shine before I show it off ! Plus I'm remodeling the interior so I've got plenty of work to keep me busy.
10-22-2014, 06:47 PM
#53
1971 23' Safari
Nashville
, Tennessee
Ordered F7 , I am fighting the brush or mill marks in the skin , that's why the G6 is taking so long.
I guess I should move most of this to the polishing thread.... ?
10-25-2014, 07:03 AM
#54
1971 23' Safari
Nashville
, Tennessee
The F7 cuts faster but leaves a lot of scratches , I think I'm going to stick with the G6 and use the F7 for rough areas like the top.
10-26-2014, 05:02 PM
#55
1971 23' Safari
Nashville
, Tennessee
All work best using the side of the buffer wheel at 90 degrees of the satin finish. Only problem is it ends up in your face and nose , got a face shield from HD today , all good.
