Old 10-09-2014, 08:55 PM   #41
Hotlead's Avatar
1971 23' Safari
Nashville , Tennessee
Originally Posted by teebs32 View Post
Here is a pick of the first pass of f9 on mine
Very nice !
I couldn’t fix your brakes, so I made your horn louder…..
Hotlead is offline   Reply With Quote
Old 10-14-2014, 07:58 AM   #42
Hotlead's Avatar
1971 23' Safari
So can I compound buff with a random orbital polisher ? it will be my first pass of polish Nuvite G6 …..
Cable Porter #7336
Old 10-14-2014, 11:15 AM   #43
teebs32's Avatar
1977 31' Sovereign
mansfield , Ohio
I don't think you will hurt anything with trying it .. If it doesn't do the job then I would switch to a rotary
teebs32 is offline   Reply With Quote
Old 10-14-2014, 11:56 AM   #44
Hotlead's Avatar
1971 23' Safari
It does spin ....
Old 10-14-2014, 02:47 PM   #45
teebs32's Avatar
1977 31' Sovereign
mansfield , Ohio
Yes but .. type of buffer usually works best when holding it flat to the surface . When I'm polishing I hold the buffer at an angle... Around 30 degrees. That has been working best for me . They also recommend using a twisted wool pad not a foam pad . Foam is good for paint . Bare metal not so much.
Old 10-15-2014, 02:49 PM   #46
Hotlead's Avatar
1971 23' Safari
I was reading the booklet I got with my Nuvite Polish and it says not to let rain dry on it or it creates hard to remove spots. I wish I could garage it but I can't , it is going to sit outside , am I wasting my time ?
Old 10-15-2014, 07:44 PM   #47
teebs32's Avatar
1977 31' Sovereign
mansfield , Ohio
It will to some extent but the more you polish the smoother the aluminum gets and the longer the shine will last . Once completely polished with a cyclo and nuvite s you may have to redo with s once a year . Like waxing a car .
Old 10-20-2014, 03:40 PM   #48
Hotlead's Avatar
1971 23' Safari
Name:	ImageUploadedByAirstream Forums1413841157.333587.jpg
My mineral spirits seem to only cloud up my work , do I have the wrong kind ?
Old 10-20-2014, 04:20 PM   #49
teebs32's Avatar
1977 31' Sovereign
mansfield , Ohio
Should be just a residue.. it will wipe off with a clean dry cloth or wait until your done working and wash it off with a mild soap ... I put mine in a spay bottle and spray it on then wipe off... What you've done so far looks great. Did you try the random orbit ?? If so how did it work ? I the dewalt buffer in pic did you make a switch?
Old 10-20-2014, 04:25 PM   #50
Hotlead's Avatar
1971 23' Safari
I Dewalted , I want to find a pad for the RO Cable Porter but have not looked yet. I just wanted to get started and knew that was the way to go. I am taking about 3 or 4 applications of the G6 to get it shinning , I wonder if I need a more aggressive grade of the Nuvite ?
Old 10-20-2014, 04:56 PM   #51
Hotlead's Avatar
1971 23' Safari
Clearcoat
The front skin was the toughest to get shining , it appeared to have more mill marks than the rest of the trailer ; it was also the hardest to strip. It took about 7 applications of G6 to shine. The sides are easier , they are taking about 4 to get shiny. Running wool pads and cleaning with the tooth spur when shiny. Hitting around 1500 RPM and going very slow.
Name:	ImageUploadedByAirstream Forums1413845760.223377.jpg
ID:	224788Click image for larger version
Name:	ImageUploadedByAirstream Forums1413845774.448093.jpg
The bottom skin has 4 applications , the top small section has 2.
Old 10-20-2014, 09:30 PM   #52
teebs32's Avatar
1977 31' Sovereign
mansfield , Ohio
Yea... That's why I went with f9. I to started with g6. Wasn't getting the results I was expecting without several passes. The f9 works a lot faster. I agree that the upper corners of the skin seems harder to shine than the rest . Looking good though. I'm waiting till spring to do the last polish with s and buying a cyclo I don't want winter weather to ruin my shine before I show it off ! Plus I'm remodeling the interior so I've got plenty of work to keep me busy.
Old 10-22-2014, 06:47 PM   #53
Hotlead's Avatar
1971 23' Safari
Ordered F7 , I am fighting the brush or mill marks in the skin , that's why the G6 is taking so long.
Name:	ImageUploadedByAirstream Forums1414025172.805160.jpg
I guess I should move most of this to the polishing thread.... ?
Old 10-25-2014, 07:03 AM   #54
Hotlead's Avatar
1971 23' Safari
The F7 cuts faster but leaves a lot of scratches , I think I'm going to stick with the G6 and use the F7 for rough areas like the top.
Old 10-26-2014, 05:02 PM   #55
Hotlead's Avatar
1971 23' Safari
All work best using the side of the buffer wheel at 90 degrees of the satin finish. Only problem is it ends up in your face and nose , got a face shield from HD today , all good.
Plasticoat vs. Clearcoat spray...?? HappyChi Clearcoat, Exterior Paint & Trim 13 07-30-2019 06:52 PM
Stripping...Clearcoat that is! InsideOut Cleaning, Stripping & Polishing 19 07-12-2003 07:59 PM
Something other than clearcoat? Bob Cleaning, Stripping & Polishing 16 03-01-2003 12:33 PM
Washing/waxing "new" clearcoat Kistler 2002 - 2005 International 13 11-21-2002 09:27 AM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 07:01 AM
