Old 01-20-2012, 04:17 PM   #1
Warwick , Warwickshire
Clear Coat Polishing
How do I get the Aluminium exterior to a finish similar to when they left the factory. Can I use a mop and polish on the clear coat or shall I Strip the clear coat and re apply?
Go
Gojet is offline   Reply With Quote
Old 01-20-2012, 05:15 PM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
What Year?
The aluminum and the factory finish depends on the model year.
That being said, clear coat can be "buffed" with varying degrees of success, I am told. I have never tried it.
In my experience, clear coat cannot be "polished."
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 01-20-2012, 05:19 PM   #3
r carl's Avatar
Lin , Ne
Go
Do as you would with a used car as they are clear coated,,, generally.
Old 02-18-2012, 12:25 PM   #4
1991 35' Airstream 350
Titusville , Florida
Buffing Clearcoat
The clear has to be in good condition and still have an adequate thickness.
Most often a clearcoat safe polishing compound will work very well. Be certain to follow the directions on the label for application equipment . Donít just guess at it. Not every buffer and pad will work well.
If the clearcoat is yellow, chalking or failed in some areas, give up and have it recoated before it gets any worse. The longer it is left go the more it will cost.
John
bfpjk1 is offline   Reply With Quote
Looking for clear coat refinishing wilkes711 Clearcoat, Exterior Paint & Trim 0 09-14-2011 11:59 PM
Clear coat on '63? esmaytum Clearcoat, Exterior Paint & Trim 2 07-28-2011 06:59 PM
what clear coat product available deelind Ribs, Skins & Rivets 0 07-24-2011 05:54 PM
Clear Coat Rust Clearcoat, Exterior Paint & Trim 7 06-04-2011 04:40 PM
Living with peeling clear coat? timmaah Clearcoat, Exterior Paint & Trim 14 04-26-2011 09:20 PM
