Closed Thread
Old 04-11-2010, 05:27 PM   #15
1994 30' Excella
Salem , Connecticut
Images: 8
Clear coat
Larry Today i bought a can of clear coat dup. color from my local auto. center. I wiped the spot with a paper towel sprayed it quick one coat and it looks 90% better. So after a quick extra fine wet sand tomorrow I'll hit it again.
Originally Posted by lsmith View Post
As you may have heard it is HOT and DRY here in Texas, however a coupke of weeks ago we did have a small rain shower. As I was walking the dog afterward I noticed BUBBLES on the upper portion of the trailer. Closer inspection revealed that the rain water had seeped between the clear coat and the trailer, now I have sheets of clear coat peeling like the after results of a sun burn. Has anyone else seen this
maintguy62 is offline
Old 04-18-2010, 06:16 PM   #16
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
so, how did it work out? pictures?
thanks!
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline
Old 04-18-2010, 07:26 PM   #17
clear coat
Store bought clear coats are designed to adhere to paint, not bare metal.
Airstream's clear coat, "is" designed to adhere to bare, chemically clean aluminum.
A touch up can be done with the original clear coat
Airstream's clear coat is available in spray cans.
Inland RV Center, In is offline
Old 04-18-2010, 09:51 PM   #18
2010 27' FB Classic
N/A , Texas
Sorry, but I just have to ask you if you are asking about Plasticoat or do you mean Clearcoat? I personally don't know what year A/S switched from one to the other. Maybe someone will enlighten me.
Bluto is offline
Old 04-19-2010, 06:44 AM   #19
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
Andy, I have a 78 Argosy that I use as my summer cabin and a lot of the paint has oxidized off of the top. I have washed and used a cleaner/polish on it but what type of finish wax would help protect it and also what type of paint would you use to repaint the whole trailer?
Argy 78
Argy 78 is offline
Old 04-19-2010, 07:38 AM   #20
Argy 78
Try a good paste wax.
Dupont Centari paint is very good. I would strip the entire trailer, as it's paint at this point, should be about dead as it can get.
If you add a couple of coats of clear auto paint to the paint job, it will last many years longer, as well as having a better shine.
Old 04-19-2010, 10:40 AM   #21
2010 27' FB Classic
N/A , Texas
Inland -Andy, what year did A/S switch from Plasticote to clearcoat finishes?
Bluto is offline
Old 04-19-2010, 10:54 AM   #22
Plasticote and clearcoat are one in the same. Just 2 names for the same thing.
However, the prefinished metal that Airstream is using, started with the 98 and 99 models. That new style finish cannot be applied in the field.
Old 04-20-2010, 04:51 AM   #23
1994 30' Excella
Salem , Connecticut
Images: 8
thanks!
It worked great the spots on the side where the awning straps wore off the clear coat look great. The spots on the front and reat top (aka nose) look good. If you email me I'll send a few pictures. I have not taken time to learn how to load pictures on the site. There are a few guy on here with much more experience in this matter than me so read their post too.
Old 04-20-2010, 06:17 AM   #24
macofpei's Avatar
2003 30' Classic
Stratford , Prince Edward Island
Send a message via Yahoo to macofpei Send a message via Skype™ to macofpei
I have a 2003 Classic with a couple of places where the coating has come off. They are about 2-3 inches wide and 10-12 inches long. This unit is originally from Arizona and had these spots on it when we bought her. She was hail damaged-- very few marks but none at the pealing sites. This is something I will have to address this spring because it really distracts from the look.
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
macofpei is offline
Old 04-20-2010, 06:58 AM   #25
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
Andy, Thank you for sharing your invaluable knowledge with all of us.
Regards,
JC Squiers
Argy 78 is offline
Closed Thread
Clear Coat(?) on Rear Bumper Peeling/flaking IrishRover2 Cleaning, Stripping & Polishing 3 01-02-2008 04:48 PM
Has Any One use microbille on clear coat? Perry Cleaning, Stripping & Polishing 6 12-10-2007 03:42 PM
Clear Coat on Everything! Sherry S Upholstery, Blinds, Walls & Interior Finishes 2 08-07-2007 08:13 PM
'66 globetrotter clear coat??? evelitalian 1965 - 1969 Globetrotter 1 06-21-2007 04:02 PM
Condition of Clear coat James Schmidt 1993 Excella 1000 2 05-15-2002 08:23 AM
