Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 05-27-2009, 11:05 PM   #1
RichHog's Avatar
Profile:  1972 25' Tradewind
Houston , Texas
Clear Coat not completely removed
A previous owner acid washed my 72 Tradewind but it didn't completely remove it along the rail or stripe that goes across the middle along toward the back end, about an inch on the top and bottom remain. How do I strip the rest of it off to make it match the acid=washed finish?
Thanks Richard
RichHog is offline   Reply With Quote
acid wash, clearcoat removal
Clear Coat on Everything! Sherry S Upholstery, Blinds, Walls & Interior Finishes 2 08-07-2007 08:13 PM
touch up clear coat... safari05-25 Clearcoat, Exterior Paint & Trim 2 10-22-2006 09:14 AM
clear coat peel joel Clearcoat, Exterior Paint & Trim 1 11-21-2005 10:30 AM
Clear Coat/ Plasticoat tmeagle1 Clearcoat, Exterior Paint & Trim 0 08-21-2005 03:37 PM
Clear coat/ plasticoat till Clearcoat, Exterior Paint & Trim 4 12-15-2003 08:43 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
