Old 04-06-2016, 08:24 AM   #1
Ruffn It's Avatar
2012 25' FB Flying Cloud
Huntersville , North Carolina
Can you help identify the issues in these pics?
Hi there AirPeeps,
Just got the 2012 FC out of hock for the season and have found these 3 issues. I think I've already found discussions / suggestions for the peeling trim. So how about the remaining two?
The spot on the side is superficial - but (being relatively new to exterior care) can you tell me what the nature of this damage is - and what needs to be done to protect if not completely repair it?
The spot under the awning is the same on both sides. It's like there's a bubble with black spots underneath. In terms of how these panels are made, what would that top layer be (i.e. what's the nature of the bubble)? And again, what could/ should I do about it?
ID:	260102   Click image for larger version
Ruffn It is offline   Reply With Quote
Old 04-06-2016, 08:30 AM   #2
dznf0g's Avatar
Oswego , Illinois
Yes, Yes and no clue!
1) is just where water and mildew has gotten under the protective tape film for the awning roller
2) Very common and continual. I replaced with a silver automotive (not chrome) molded in color molding, as the AS replacements wil just do the same thing in a couple years.
3) ???? is that on the clear coat or under it? Never seen anything like it. O has the clear peeled off? Not common, but sucks.
-Rich-
Old 04-06-2016, 08:39 AM   #3
Ruffn It's Avatar
Rich,
So, about that "protective tape film" ... I envision me trying to peel it up a little to clean under there and the peeling to never stop. Any suggestions for what (if anything) needs to be done to clean this up and re-seal it?
The spot on the side is from accidentally letting the ladder touch the side. So it's like a stationary scrape (if that makes sense). How would I know if it's on the clear coat or under it? I'm going to say under it or the clear coat got completely scraped off. I can feel a ridge along the outline with my finger.
Deb
Old 04-06-2016, 08:55 AM   #4
dznf0g's Avatar
Oswego , Illinois
I never have done anything with the mildew under the tape. It's on my "someday" list. There are some 3M films available to replace. I think it is due to just sloppy installation. Lifting and cleaning it will prevent it from sticking again.
If the spot is just aluminum ladder abrasion, I'd try Paint prep solution (like PrepSol brand) available at any auto store. It won't damage the clear coat.
-Rich-
Old 04-06-2016, 09:08 AM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
On the tape I would score a straight line with a sharp Xacto blade with a straight edge and peel of that end of the tape, clean and then apply some wax. I did that with the tape on my rear window awning.
If you have some automotive liquid paint scratch remover try that after washing the blemish or try Rich's suggestion.
Kelvin
Old 04-06-2016, 10:58 AM   #6
Ruffn It's Avatar
Thanks for the suggestions so far. About the blemish - does it matter that it's 6" long and 1.5" wide? Do the suggestions assume a much smaller area?
Deb
Old 04-06-2016, 11:24 AM   #7
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
Is it an indentation (inny or outy?) If it is raised it may be transfer from softer aluminum on ladder. Might try using tooth paste on a small area in the middle to see if it clears the darker mark some.
Dennis
dennis3751 is offline   Reply With Quote
Old 04-06-2016, 11:38 AM   #8
dznf0g's Avatar
Oswego , Illinois
Deb
No, but it sure looks odd.
-Rich-
Old 04-06-2016, 11:59 AM   #9
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Where did you get your molding, dznf0g? Im having to consider replacing mine where the plastic film over the chrome is starting to peel - Going to need a couple of long rolls for a 34 footer!
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 04-06-2016, 01:08 PM   #10
dznf0g's Avatar
Oswego , Illinois
Here's the thread:
http://www.airforums.com/forums/f44/...ts-110776.html
-Rich-
Old 04-06-2016, 01:21 PM   #11
E Pluribus Aluminus
Jaxon's Avatar
1967 22' Safari
2005 30' Classic
Rockport , Texas
Thanks, Rich!
Bill & Kim
Old 04-08-2016, 02:21 AM   #12
1973 31' Sovereign
Middletown , California
I would be VERY careful about using a sharp blade on aluminum because if you cut into the metal it can be the start of a stress crack!
ijustlee is offline   Reply With Quote
Old 04-08-2016, 06:51 AM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
Deb
Deb,
"I can feel a ridge along the outline with my finger."
I do believe you've lost the clear coat...Peeling Clearcoat, not all that un-common.
Ours......
More....
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-10-2016, 10:46 AM   #14
Ruffn It's Avatar
Thanks Bob for those pics. I think that's our problem.
Help us identify these wires please! dillonation Electrical - Systems, Generators, Batteries & Solar 5 05-06-2015 10:41 AM
Can you identify these pipes? Brian Schulz Plumbing - Systems & Fixtures 1 06-13-2014 06:06 AM
Can you help me identify this trailer? hislife Trailer Values 3 09-07-2012 10:28 AM
Can anyone identify these? bullydogsmom General Interior Topics 7 04-06-2009 05:20 AM
Can you help me identify my trailer? aprimosch Title, VIN & Registration 18 05-05-2007 10:27 AM
