Old 05-01-2012, 06:07 AM   #1
New braunfels , Texas
I've attached a photo of the outside of an Airstream. Can the sanding (or whatever caused the swirls) be buffed out giving her a like new skin? Thank you
Sojourn is offline   Reply With Quote
Old 05-01-2012, 06:35 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
What were they thinking....
I'm sure those with polishing experience will chime in to help.
It's hard to tell from the pic's, it does look like the scratches are pretty deep and may have compromised the alloy coating.
POI...$6995 may be a little over the top, are you the new owner?
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 05-01-2012, 06:45 AM   #3
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Nuvite makes polishes for aluminum and is what I used to polish mine. They may be able to recommend something to you if you contact them
http://www.nuvitechemical.com/c-56-m...ii-system.aspx
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 05-01-2012, 06:49 AM   #4
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I'm going think that I doubt it - its probably through the alclad - which is a very thin layer that gives it its shine - at minimum it will take an incredible amount of work -
What did they use? I know some have used Brillo, ....... this looks like they used a grinder
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 05-01-2012, 06:50 AM   #5
SteveH's Avatar
Common Sense , Texas
I have no experience with polishing Airstreams, but I have experience with polishing in general, and automotive body work, and I would say if you can "feel" the scratches with a fingernail, polishing them out is not practical.
However, it looks like a perfect initial start for a paint job.
Old 05-01-2012, 07:01 AM   #6
Thanks for the input. I didn't buy; rather located it. The current asking price is well below the sticker price. I just can't imagine owning an airstream that may be unable to regain its smooth shine. If I take the time to drive the 300 miles I'll give it the fingernail test
Thanks again. The search continues...
Old 05-01-2012, 07:05 AM   #7
Levon's Avatar
1985 27' Sovereign
1981 22' Excella II
Colbert , Georgia
Images: 168
Options
It has been my experience that once sanded the alum. cannot be brought back to a mirror shine without a great deal of effort and $, and even then, it's not as deep of a shine because of the removal of alum. clad. (Even less pure alum. with the 70's era). With polishing, there is only oxidation removal and a shifting or smoothing of the micro valleys and hills in the alum.
At this point, one might consider a paint job with a clear coat ....that also is expensive, but I have seen several that look very similar to the original factory look. Good luck with either direction you decide to take.
Best Regards,
Levon
Levon is offline   Reply With Quote
Old 05-01-2012, 08:30 AM   #8
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Correct me if I'm wrong - how did you come about the thought that those are scratches? They look like a poor attempt at removing the clearcoat PRIOR to doing a polish job on it. If that's the case then it's just a matter of removing the rest and polishing - something I would rather not do either.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 05-01-2012, 08:31 AM   #9
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Agh - NO - scratches it is - sorry.
Old 05-01-2012, 09:27 AM   #10
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
vinyl wrap
there are a number of places now that will "wrap" a vehicle by cutting vinyl "decals" (big un's). this would be another option. it is my understanding this method is less expensive than painting. still gonna cost, tho.
wmarsha is offline   Reply With Quote
Old 05-01-2012, 02:14 PM   #11
Kevin245's Avatar
Wow. Looks like a good start for paint prep. I've seen painted Airstreams that looked so good you'd never know they were painted.
BigAl's rig looks amazing.
Eleanor Roosevelt
Old 05-01-2012, 03:44 PM   #12
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
Just depends how deep the sanding went. I used a paint scraper on my Argosy and most scratches polished out or well enough you can not see them from 5feet away. It would be a lot of work but it could be made to look better. The easiest would be take a paint roller to it and paint it like an Argosy.
nick6930 is offline   Reply With Quote
