Old 04-09-2010, 02:18 PM   #1
'06 75th Winick Prototype
2006 19' International CCD
1968 22' Safari
The Swamps of Hell , Lousy-Anna
Can Current Molding Inserts Be Changed To Blue?
Hi everyone...
I was wondering if the new trailers still have "inserts" in both the beltline molding and the lower side molding. I know the newer current trailers have what looks to be a chrome insert...
My questions are:
1) Is this an actual insert that is removable?
2) If the inserts ARE exhangable, are replacement moldings available in blue? If so, what size would I need for both the bottom molding as well as the Classic style beltline molding?
Please let me know if this is feasible and what would be involved in changing out the molding inserts (if in fact the newer trailers HAVE inserts).
Thanks!
Jeff
ggoat!!! is offline   Reply With Quote
Old 04-09-2010, 02:32 PM   #2
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I have replaced the blue moldings on my '85. Easy to do. Different sizes are available from AS dealers. I first ordered them from my CT dealer RV Legends where I bought our AS last year (by the way excellent people to work with!). The balance of what I needed was from Inland RV, it was on sale, check it out. Also very nice people to work with prompt service etc.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 04-09-2010, 02:40 PM   #3
1968 22' Safari
Would that apply to a 2006 trailer? Are the newest trailers' moldings able to be changed just as easy and in the same way as an '85?
Thanks!
Old 04-09-2010, 10:28 PM   #4
1968 22' Safari
Anybody?
Old 04-10-2010, 12:24 AM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by ggoat!!! View Post
Hi everyone...
My questions are:
Thanks!
Jeff
Thanks!
Anybody?
Hi, "Anybody" here. The older inserts slip into a channel of some sort; And the newer ones like on my trailer are installed with two sided tape, like used on newer car's body side mouldings. So the short answer would be No.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-10-2010, 02:50 AM   #6
1968 22' Safari
Thanks for responding "Anybody"!
So...even the moldings along the bottom are just a one-piece stick on molding?
Jeff
Old 04-10-2010, 09:49 PM   #7
Salem , Oregon
Images: 18
Jeff
Hi, two piece; The aluminum base channel, and the stick on chrome plastic moulding.
2005 Safari 25-B
Old 04-10-2010, 11:31 PM   #8
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The chrome colored insert in the extrusions on the newer trailers can be peeled off. Sometimes it comes off by itself. But so far as know, it can only be replaced by the same thing if you use Airstream materials. I imagine you could replace it with a different color material and use two sided tape or glue on it. The lower moulding at the bottom of the aluminum is a little larger than the one used on the beltline.
I am confused because the original poster has a '68 trailer but is asking about the mouldings on newer ones.
Gene
Old 04-11-2010, 04:08 AM   #9
1968 22' Safari
Hi Gene...thanks for clearing that up.
I'm in the process of buying a new 19ft...I'm going to be towing with a blue over silver Chevy SSR and am looking for ways to add the vintage 70's blue and silver vibe to the new trailer without it looking "wrong" and was hoping to add the blue insert as an homage to the older models while also matching my truck better.
Jeff
Old 04-11-2010, 09:59 AM   #10
Master of Universe
Gene's Avatar
That explains it. The older inserts may be thicker, but I'm unsure of that. Cutting them to the proper width is best done on a machine that cuts things like that. Look around, you may find something from the world of plastic. We thought of blue moulding at the beltline, but it was too hard to do.
Gene
Old 04-11-2010, 03:31 PM   #11
Salem , Oregon
Images: 18
Hi, check out auto parts stores for rolls of body side mouldings. Pep Boys has some, and maybe different sizes and colors can be ordered. I wouldn't mind changing mine to blue too, if and when mine go bad. I think it would look great; Go for it.
2005 Safari 25-B
stripe and trim inserts ALANSD Clearcoat, Exterior Paint & Trim 13 08-01-2006 11:05 AM
Installing vinyl inserts juel All Argosy Trailers 5 12-14-2004 05:01 PM
Caulking above blue molding ? Happycampers Leaks - Weatherstrips, Gaskets, Caulks & Sealants 19 12-11-2004 06:03 PM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Wood Inserts on the Fridge? Porky Pig Refrigerators 18 11-12-2003 03:22 AM
