Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 07-14-2007, 01:20 PM   #1
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
Blue Tape on rub rails
Does anyone know where I can get the blue vinyl tape that is used on the rub rails at the floor seem and about mid-height on the 70's trailers? I'm starting to replace rivets and will eventually like to replace the blue striping. Thanks!
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 07-14-2007, 02:09 PM   #2
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
It's sold by the width and by the foot by Airstream dealers.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-14-2007, 05:30 PM   #3
beckybillrae
beckybillrae's Avatar
Profile:  1986 31' Sovereign
Schererville , Indiana
Inland RV has it too. Don't forget to caulk the rivets UNDER the rubrail & beltline when you have it off. I had some leaks through there that took me forever to find.
Becky
beckybillrae is offline   Reply With Quote
Old 07-14-2007, 06:34 PM   #4
cameront120
This is why I'm redoing the rivets at these locations. I want to be certain I'm not getting any water ingress at these points.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 07-16-2007, 10:59 AM   #5
dnrtheil
dnrtheil's Avatar
Profile:  1964 24' Tradewind
Portage , Michigan
Most sign shops can get rolls of stripping. Can also cut them down to any width.
dnrtheil is offline   Reply With Quote
Old 07-16-2007, 12:38 PM   #6
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
The blue tape is not actually tape but an extrusion profike made from what I think is an EVA/ LDPE plastic compound. For some reason the material from Airstream is not very UV resistant and needs to be replace every 7 years or so with Midwest sun exposure. In Arizona it would not last as long.
Old 07-16-2007, 01:37 PM   #7
cameront120
The stuff on my trailer is definitely tape. I've already removed some of it. Perhaps the extrusion was removed in the past and replaced with vinyl tape.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 07-16-2007, 03:11 PM   #8
mello mike
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 22
Dumb Question...
I've never worked with this stuff, but is it self-adhesive?
2003 Ford Excursion (6.0L PSD)
Prodigy / Equal-i-zer / Honda EU2000i / Xantrex Link 10
U.S. Navy (Retired)
Airstream Life Contributor
Air#5661 / WBCCI#--
My Refurb Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-16-2007, 04:58 PM   #9
53flyingcloud
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
A word..
Mello Mike, the edge of the blue trim is rimmed slightly to fit inside the rib. What you do is get it started on one side and, push down under the top. The trim goes in as slick as can be. No glue~
For those thinking of using tapes, I would say, it's a poor economy to use that as this trim also helps to keep water from wicking into the trailer via the rivets.
The stuff is NOT cheap..Usually around 1.50$ per foot, depending on the width.
53flyingcloud is offline   Reply With Quote
Old 07-16-2007, 05:09 PM   #10
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Your trailer "did" have tape in all the moldings. It never had paint, or any other type insert.
Vinyl inserts for the moldings were not used until the 1974 models.
Instead of using tape, most owners of the 73 and older trailers, simply paint the center of the moldings blue.
If you wish to paint them, you must sand the center of the moldings, mask them off, apply primer paint, then blue paint, and then clear paint (not plasticoat).
That will last many years. The tape was good for maybe a year or two, and then fell apart.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 07-16-2007, 08:22 PM   #11
mello mike
mello mike's Avatar
Phoenix , Arizona
Images: 22
So, Andy. What about the tape used today? Will it last only a year or two like the older stuff? Do you recommend painting?
U.S. Navy (Retired)
Air#5661 / WBCCI#--
My Refurb Blog:
Old 07-17-2007, 08:44 AM   #12
cameront120
Thanks Andy, I started second guessing myself and went home to double check. And, yes, it is indeed vinyl tape. I don't know the age of this tape, as I've had the trailer for 1 1/2 years. I think I'll look into painting.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 07-17-2007, 09:04 AM   #13
Commercial Vendor
Painting will last a long time "IF" you prepare the surface properly and use a high quality paint.
20 years or more is certain.
Tape is tape is tape.
Tapes will last 3 to 5 years, maybe.
But think about what you have to do to install tape. You must drill out all the rivets, install the tape, find the original holes, and then reinstall the moldings with rivets.
Then consider yourself "lucky" if you can find a colored rivet that will match the tape color.
Installing tape over the rivets, is time and money tossed down the drain.
Bottom line?
Paint.
Inlandrv.com
800-8777311
Old 07-17-2007, 10:53 AM   #14
Cos
Profile:  1973 21' Globetrotter
Middletown , Rhode Island
Where would one get the official blue paint used by Airstream? I can't think of anything blue on my 73 trailer that I can bring to the paint shop to match.
Cos is offline   Reply With Quote
Blue paint uwe Clearcoat, Exterior Paint & Trim 16 07-28-2008 05:53 AM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
blue rub rail paul k Clearcoat, Exterior Paint & Trim 0 04-27-2003 12:52 PM
Painting your Airstream jkleven Clearcoat, Exterior Paint & Trim 25 07-18-2002 03:32 PM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
