Old 05-26-2007, 06:43 AM   #15
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I've stripped all the clearcoat off my trailer already. I used the mineral spirits first (as recommended by Inland Andy) & it didn't touch the glue. Then I used goo-gone. Finally I used BIX stripper. Had to use a metal scraper to get all the glue off & did it twice. Then I used a regular razor to scrape off as much as I could (don't really care about scratches since the stripe will cover it). The question is..does it matter if there is any trace of glue left in the etching for the new stripe to stick well? I think I'll give Gary's idea a shot & try a small piece & see if it sticks well. Anyone else have any experience with stripes? Thanks!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-26-2007, 07:26 AM   #16
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
When I removed the stripe last year on the excella 2 I had the same difficulties. I tried aircraft stripper, and 3m adhesive stripper, but neither worked that well. Walmart had a cheap gel stripper in their paint section that did the job much better. I also agree with getting a couple of plastic putty knifes, or plastic scraper blades. When I went to replace it I found it was less expensive to have the stripe painted then to buy the decal roll from airstream.
Charlie
Pacerized is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Blue paint uwe Clearcoat, Exterior Paint & Trim 52 09-17-2014 07:41 PM
Stripe on Bubble??? kzener40 Airstream Motorhome Forums 11 09-12-2002 06:40 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
