Old 12-10-2010, 12:12 AM   #41
1970 18' Caravel
Oakland , California
blue band around the trailer
I understand that there is supposed to be blue tape but since I don't know about that yet and want something in the meantime, I painted the band, rivet heads and all, and then sanded the molding that was oxidized anyhow so we could be sloppy with the paint. I did the tail-light casting and the big letters also. The letters were oxidized so I sanded across the blue sloppy paint but need to sand deeper to get past all the pits. I am tempted to use my belt sander but Lord help me if I slip! Here are shots of the band Index of /airstream/101010_Blue_line --Mike Diggles in Oakland, Calif.
mdiggles is offline   Reply With Quote
Old 12-10-2010, 05:39 AM   #42
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I used Sail Blue Rustoleum spray paint for my stripes. Lots of masking with blue painters tape. I like how it turned out.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 10-24-2013, 03:53 PM   #43
Razinni's Avatar
1977 31' Sovereign
Atlanta , Georgia
I'm wondering if it would be sacrilegious to change the blue color on the outside of our 73 international. Our tow vehicle is green and I think a bit of that same color on the rig would look good.
"The road goes on forever and the party never ends" - R.E.Keen
Razinni is offline   Reply With Quote
Old 10-24-2013, 04:04 PM   #44
r carl's Avatar
Lin , Ne
I always liked the ford blue that they painted their engines with.
Old 05-21-2014, 07:17 PM   #45
'73 Ambassador
1973 29' Ambassador
Angel Fire , New Mexico
Blue Paint works!
I used Rustoleum Royal Blue and it turned out great. I used Frog tape, make sure you take your time and get a good seal, remove immediately with a forward pulling motion to give a clean "cut". I did two coats on my 29' Ambassador and still have more than half the pint left.
leoks2013 is offline   Reply With Quote
Old 05-21-2014, 09:29 PM   #46
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Who cares if people don't care for your green paint?
FYI, I painted my trim RED.
Old 09-13-2014, 09:44 AM   #47
1982 31' Excella
Hemingford , Nebraska
I think the stripe around the middle (bellyband?) of my '82 Excella is tape because it looks like cracked plastic. I'm good with using paint to replace, but what do I use to remove the existing blue product?
Name:	ImageUploadedByAirstream Forums1410622993.024546.jpg
mwernke is offline   Reply With Quote
Old 09-13-2014, 11:57 AM   #48
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
That could be a painted vinyl strip and the blue paint is cracking and peeling away from the vinyl. The white stripes are a decal. If it is a vinyl strip, you can remove it and then paint the bare aluminum underneath. That's what I did with mine.
4RXLA is offline   Reply With Quote
Old 09-13-2014, 02:55 PM   #49
1981 31' Excella II
New Market , Alabama
Looks like mine. Blue paint with a darker blue pin stripe over that. I have not tackled that yet. I will probably go all paint instead of pin stripe tape over paint. I don't think I would use cheap spray paint considering the amount of work required.
Perry
Attachment 221671
Old 09-13-2014, 02:56 PM   #50
1982 31' Excella
I will remove the vinyl. But how? Goo be gone or heat gun?
Old 09-13-2014, 03:35 PM   #51
1981 31' Excella II
You might try an iron with a wet rag under it to soften the glue. I expect paint stripper will get it off as well but use the gel kind so it does not drip into areas you don't want stripped.
Perry
Old 09-13-2014, 05:26 PM   #52
4RXLA's Avatar
Images: 33
I thought the vinyl strip was either riveted or glued to the aluminum skin and that you had to remove the rub rail to remove it?
Old 09-17-2014, 07:41 PM   #53
1982 31' Excella
Wow, that Rustoleum "paint" is messy. Appears more like varnish, but mine was aluminum color, for a different project. Just saying, be careful with drips and splatters.
What kind of interior paint 1971 Overlander/End caps dingy riverdreamer Upholstery, Blinds, Walls & Interior Finishes 5 05-24-2004 09:36 AM
Old Paint Help... Over59 Clearcoat, Exterior Paint & Trim 2 09-27-2003 02:53 PM
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 08:18 PM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 08:14 PM
