12-10-2010, 12:12 AM
#41
1970 18' Caravel
Oakland
blue band around the trailer
I understand that there is supposed to be blue tape but since I don't know about that yet and want something in the meantime, I painted the band, rivet heads and all, and then sanded the molding that was oxidized anyhow so we could be sloppy with the paint. I did the tail-light casting and the big letters also. The letters were oxidized so I sanded across the blue sloppy paint but need to sand deeper to get past all the pits. I am tempted to use my belt sander but Lord help me if I slip! Here are shots of the band Index of /airstream/101010_Blue_line --Mike Diggles in Oakland, Calif.
12-10-2010, 05:39 AM
#42
1958 26' Overlander
Mesa
I used Sail Blue Rustoleum spray paint for my stripes. Lots of masking with blue painters tape. I like how it turned out.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
10-24-2013, 03:53 PM
#43
1977 31' Sovereign
Atlanta
, Georgia
I'm wondering if it would be sacrilegious to change the blue color on the outside of our 73 international. Our tow vehicle is green and I think a bit of that same color on the rig would look good.
"The road goes on forever and the party never ends" - R.E.Keen
10-24-2013, 04:04 PM
#44
Lin
, Ne
I always liked the ford blue that they painted their engines with.
05-21-2014, 07:17 PM
#45
'73 Ambassador
1973 29' Ambassador
Angel Fire
, New Mexico
Blue Paint works!
I used Rustoleum Royal Blue and it turned out great. I used Frog tape, make sure you take your time and get a good seal, remove immediately with a forward pulling motion to give a clean "cut". I did two coats on my 29' Ambassador and still have more than half the pint left.
05-21-2014, 09:29 PM
#46
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Who cares if people don't care for your green paint?
FYI, I painted my trim RED.
09-13-2014, 09:44 AM
#47
1982 31' Excella
Hemingford
, Nebraska
I think the stripe around the middle (bellyband?) of my '82 Excella is tape because it looks like cracked plastic. I'm good with using paint to replace, but what do I use to remove the existing blue product?
09-13-2014, 11:57 AM
#48
1977 31' Excella 500
West Sacramento
That could be a painted vinyl strip and the blue paint is cracking and peeling away from the vinyl. The white stripes are a decal. If it is a vinyl strip, you can remove it and then paint the bare aluminum underneath. That's what I did with mine.
09-13-2014, 02:55 PM
#49
1981 31' Excella II
New Market
, Alabama
Looks like mine. Blue paint with a darker blue pin stripe over that. I have not tackled that yet. I will probably go all paint instead of pin stripe tape over paint. I don't think I would use cheap spray paint considering the amount of work required.
Perry
Attachment 221671
09-13-2014, 02:56 PM
#50
1982 31' Excella
Hemingford
, Nebraska
I will remove the vinyl. But how? Goo be gone or heat gun?
09-13-2014, 03:35 PM
#51
1981 31' Excella II
New Market
, Alabama
You might try an iron with a wet rag under it to soften the glue. I expect paint stripper will get it off as well but use the gel kind so it does not drip into areas you don't want stripped.
Perry
09-13-2014, 05:26 PM
#52
West Sacramento
I thought the vinyl strip was either riveted or glued to the aluminum skin and that you had to remove the rub rail to remove it?
09-17-2014, 07:41 PM
#53
1982 31' Excella
Hemingford
, Nebraska
Wow, that Rustoleum "paint" is messy. Appears more like varnish, but mine was aluminum color, for a different project. Just saying, be careful with drips and splatters.
