Old 06-07-2011, 09:53 PM   #1
cutterbug's Avatar
2004 19' Bambi
afton , Virginia
Black letters peeling
What's the best fix for the black airstream letters peeling on my 2004 Bambi? (Both front and back) Are they glued on?
cutterbug is offline   Reply With Quote
Old 06-07-2011, 10:08 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi cutterbug. The plushy soft plastic AIRSTREAM letters? Is this what awaits us all? I believe they are applied from a sheet and have a tape-like adhesive.
Has your '04 been stored inside or outside?
5 meter Langford Nahanni
Old 06-07-2011, 10:43 PM   #3
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
All my lettering turned "Pink"!
They used to be gold.. so I am told. The friendly airstream dealer told me its about $600+ to replace all the lettering. So now I call it salmon colored. Im good with that.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 06-07-2011, 11:10 PM   #4
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
There is a certain amount of moisture in Vinyl cutouts...when the moisture gets up and leaves, then the edges will begin to tell you so. Same thing happens with a roll of masking tape at its edge on the roll. There is no fix that I know of for now other than to replace them.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 06-08-2011, 01:04 AM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Vinnie
Hi, I think the trailers with the "Pink" letters are girls.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-08-2011, 08:01 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
$600+...all ting's AS are $$$$
AC cover cracked all over the place, was going to replace with aftermarket, called AS parts, decals cost as much as new cover....fiberglass all the cracks, paint a nice blue stripe around bottom edge to help hide repair, na, na, na, na, na, na... ASP
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 06-08-2011, 09:54 AM   #7
moderator
Airslide's Avatar
Wilton , California
Images: 50
Ha ha.. I will deal with you at the next rally mr.
Old 06-08-2011, 11:00 PM   #8
Salem , Oregon
Images: 18
Hi, my A/C shroud was cracking so after a few searches, I ordered a new one from "ICON -Direct". This one has a limited lifetime warranty and they say it will be the last one that you will ever buy. It is made out of a different kind of plastic, actually thinner. The shape is slightly different, but a perfect fit. I ordered mine through E-bay. I was going to save my original shroud, but it broke more just putting it in the box and removing it. I started to cut it up with an electric saw, but it just crumbled. I ended up breaking it into small pieces with my bare hands to put it in my trash can. For the $105.00 for a new shroud, I think you should replace yours too.
ID:	132051   Click image for larger version
2005 Safari 25-B
Old 06-09-2011, 06:26 AM   #9
Thumbs up
Bob,
Did you paint it, or is that how it came? Looks great.
Maybe instead of replacing the AS decal, I'll go with a nice "Cloudsplitter" one from the sign shop....30 bucks for the pair.
When we first got our trailer I had the normal black tank vent leak.
While up there I noticed both the skylight cracks and the AC shroud cracks.
Guess JC figger's we never go up there on our PDI any way.
Amanamus
"Tahawus"
Old 06-09-2011, 11:09 PM   #10
Salem , Oregon
Images: 18
Hi, Robert. My A/C shroud came as it looks, white. They also have them in black. I just went to their site and it is $99.50, but I ordered mine from them through E-bay. I thought about putting AIRSTREAM letters on each side, but I like it plain. The pictures are of my original A/C shroud and only show one of the cracks.
ID:	132110   Click image for larger version
2005 Safari 25-B
Old 06-12-2011, 06:09 PM   #11
cutterbug's Avatar
2004 19' Bambi
afton , Virginia
Bobstream....my unit is stored under cover....20x30 shelter open sides. I guess I'll have to bite the bullet sooner or later and buy letters....either that.....let the little puffy letters go and have a professional paint them on once and for all.
Old 06-12-2011, 06:14 PM   #12
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
You could let them fall off. Everybody knows it is an Airstream.
If the black letters turn to pink, does that mean the trailer had a sex change operation?
Gene
Old 06-12-2011, 06:16 PM   #13
moderator
Airslide's Avatar
Wilton , California
Images: 50
Gene
Rumor has it they were gold to begin with but... maybe...
Old 06-12-2011, 06:26 PM   #14
Lily&Me's Avatar
Normal , Illinois
We got a little tube of something at AutoZone, especially made for decals, etc. It worked fine. We eventually had to replace them, ordered a set from JC and off we went.
Maggie
« Henry Roof Coating | Top | - »
How much black / grey is enough? Darkspeed Waste Systems, Tanks & Totes 5 05-26-2011 08:39 AM
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 10:52 PM
Living with peeling clear coat? timmaah Clearcoat, Exterior Paint & Trim 14 04-26-2011 10:20 PM
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 07:50 AM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 01:50 PM
