06-04-2015, 02:59 PM
#21
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
just checking on your curiosity level guys...
Still One Nation under GOD
2 chronicles 7:14
06-04-2015, 03:36 PM
#22
Sunset Beach
, North Carolina
Black is the new blue
It is under construction, but it is black. I also found some black Vulkem 116 to seal my new LED lights.
Actually its an older picture, and the rear end looks a little better than that.
06-04-2015, 11:35 PM
#23
1976 27' Overlander
Tampa
Curious! Curious! !!
06-05-2015, 12:33 PM
#24
1976 25' Tradewind
Flushing
, Michigan
Ok, it is blue, not black...
Here is a shot of my LandYacht emblems (1976 25'), one complete, one untouched with almost 40 years of patina. I used emery paper and subsequently finer grades of wet or dry paper, then brush painted the inset portion of the emblem with blue Rustoleum (not quite the shade I expected). After it dried for a few days I repeated the paper process. I like it, but maybe red would look better?
06-05-2015, 12:42 PM
#25
1976 25' Tradewind
Flushing
, Michigan
Sorry, I thought I understood how to upload a phot, but apparently not
06-09-2015, 06:22 PM
#26
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Badges are not installed yet, will probably go up this weekend...
It was a little more work than expected.
The badges were powdercoated in full black, and the grey done with POR15.
A little time consuming but happy with the results.
2 chronicles 7:14
06-09-2015, 06:33 PM
#27
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
some pictures of the process
2 chronicles 7:14
06-09-2015, 06:46 PM
#28
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
have some fun with the letters as well.
got them stripped, pass them thru a bench grinder with a wire brush wheel and a lot of patience with the little brush and more POR15
2 chronicles 7:14
06-09-2015, 06:49 PM
#29
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
patience.....
2 chronicles 7:14
06-09-2015, 06:53 PM
#30
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
got so excited that next I'm going after this....
2 chronicles 7:14
06-10-2015, 06:54 AM
#31
Sunset Beach
, North Carolina
Are all the metal cans in pretty good shape on the light assembly? Mine were all toast.
06-10-2015, 07:20 AM
#32
1971 21' Globetrotter
Arvada
I did all of this awhile back. I still have not installed the emblems yet. The tail light housing were the challenging part. Its is detailed in my thred belw on posts 276, 278, and 298
06-10-2015, 02:31 PM
#33
1976 27' Overlander
Tampa
I did Kip's helicoil method, and it worked awesome. Could not bring myself to just pop rivet those back in... was a HUGE leak source. It took loads of sealant to fill all the gaps, and the SS fasteners snugged it up nicely against the shell.
The only thing I wish I would have done, is sand the corrosion off better, and then clear the whole thing. Instead I repainted the black, and cleared it, but I only polished the outside perimeter.. its already corroding again.
06-11-2015, 01:30 PM
#34
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
You can get new solid aluminum cans at Vintage trailer supply http://cdn3.volusion.com/wckp9.3xkgs...jpg?1397821778 For 1969-1974 trailers
and new pigtails for the bulbs from Dan at LED4RV (two 1156 SKU508 and two 1157 SKU516) My rear light assemblies are all completely redone now and they look awesome. I was able to salvage a few of the original cans by glass beading them and painting them with POR-15.
but...I used pearlecent blue on my lights and full color on my badges though so I'm not sure I'm allowed in this thread
06-18-2015, 09:56 AM
#35
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Would you need them?
I will have no use for them, I painted them with POR15 in case someone may want them.
2 chronicles 7:14
05-30-2016, 07:11 AM
#36
1972 27' Overlander
1971 31' Sovereign
Orlando
I painted my '73 letters Ford blue and the placquards graphite. Trim line also graphite. Like it!
The Shifty Drifter.
2018: 7500 miles: FL to Co
2019: 7500 miles: FL to Co
05-31-2016, 05:42 AM
#37
Sunset Beach
, North Carolina
Hey GuitarmanFL, How about a pic.
Mike
