07-22-2019, 08:31 AM
1981 31' Excella II
New Market
, Alabama
Best White Roof Coating
I have heard good results from this stuff but it ain't cheap. I was thinking of putting this on the roof of the Airstream. I wonder of 1 gallon will do the roof between the awnings and the front end cap upper seam? Any other coatings out there that last and won't mildew?
For those of you that don't know, white is the best roof coating for keeping the trailer cool. It not only reflects light coming in but it is also good at radiating the heat away. Polished aluminum is not great at radiating heat away.
https://www.amazon.com/Henry-Tropi-C...s%2C178&sr=8-1
Perry
07-22-2019, 10:15 AM
2015 28' Flying Cloud
Newtown
, Pennsylvania
4" Eternabond. I put that (bleep) on everything.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
400ah LiFePo4, 800 watts solar, 2x eu2000i Propane
PD9160 converter, Prosine 1800 inverter
2x Victron 100/30 Smart Solar, Victron Smart Shunt
07-22-2019, 11:42 AM
2010 25' FB Flying Cloud
Davenport
, Iowa
I used Bus Kote. I did 2 coats from 1 inch outside rivets and all but under AC. It's been 2 years and coach is cool and it insulates against sound. I have a 25 ft FC.
07-22-2019, 12:36 PM
1990 25' Excella
Sisters
, Oregon
I would really like to paint the top of my trailer. It’s the only part of the trailer, other than the blue stripe, that shows it’s age (29 years). Plus I like the look and the cooling effect.
Due to my loss of coordination over the past few years (it’s come down to bragging about glory days - the older I get the better I used to be, but I digress) I’m reluctant to climb on the roof of my trailer. I know I’m getting to the age where I should probably hire some things out but I’ve been DIY my whole life and it’s tough to change. Can you do a good job from the side with a roller and a long handle?
John
John Audette
Air Cooled Porsche Specialist -
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
07-22-2019, 12:52 PM
2019 22' Sport
High River
, Alberta
John
A length of aluminum extension ladder, and couple of short pieces of pool noodle slit with a knife to prevent the ladder from damaging the side, and I was able to wash and wax the roof of our trailer a couple of weeks ago. If you are reach with a short pole, you should be fine.
Getting it good and clean is most important. A good scrub with dish detergent should remove any grease or wax on the roof.
07-22-2019, 12:56 PM
1981 31' Excella II
New Market
, Alabama
You should be able to paint it will a roller on the end of a broom stick but you need to clean the roof and get all the mold etc off the roof. Don't tell anyone but I actually used bleach to kill the mold up there with no ill effects on the trailer. Probably not something to do on a new trailer with the corrosion issues.
Perry
07-23-2019, 11:38 AM
ObviouslyKnot
KAILUA
, HI
Don't know if white GACO silicone sticks to aluminum (should based on marketing), but at high noon in Hawaii, it feels like cool porpoise skin.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
07-23-2019, 12:49 PM
Experienced Learner
2000 34' Excella
Somewhere
, Earth
BusKote
We used BusKote, and the results were better than expected. It was applied in Texas last September, and there was over a 10 degree drop inside the day after doing the first coat, with the original Penguin AC.
We can now keep the inside of our 34' in the mid to upper 70's even when it's in the upper 90's outside, with a single 13.5k AirCommand AC unit. Two things that help tremendously, having awnings all of the way around, and using enough roof coating.
We used 1 gallon of the primer, and 2 gallons of the coating, plus 1 gallon of the clearcoat finish. Unfortunately we used too much of the clearcoat, which caused some slight yellowing, but it does make it easier to keep clean. In the attached pic you can see the difference between the clearcoat finish, and the freshly applied BusKote when we installed the new AC.
Make sure that a silicone coating will stick well on aluminum, you might need some sort of primer. It is not too difficult, but it's definitely not something you want to redo.
07-23-2019, 03:24 PM
1959 24' Tradewind
Twin Falls
, Idaho
Bus Kote for me
I also used Bus Kote and purchased from Amazon. I taped off the area I wanted coated, rolled it on with a short nap roller, brushed some areas. It's really thick stuff and only needed one application. I just used a gallon on my 24ft Tradewind, went from end cap to end cap and down just past the first longitudinal seam. They have a top coat too, but I didn't use it.
Regards,
Tony
07-23-2019, 03:37 PM
1993 34' Excella
Estancia
, New Mexico
I did not have to climb on the roof. From a ladder I was able to reach to the center. I am kind of tall though. I used several ladders: a lightweight 7 foot ladder and an articulating ladder.
I used Bus Kote, also the Bus Kote Clear finish.
If you put bus Kote on too thick it will yellow but the yellow goes away after a few months.
07-23-2019, 06:30 PM
1985 25' Sovereign
Olympia
Streamer85 Roadhouse
03-26-2020, 02:24 PM
2009 30' Classic
a city in west GA
, Georgia
May I ask what you used as a Clear Coat sealer? thanks!
03-27-2020, 10:14 AM
Experienced Learner
2000 34' Excella
Somewhere
, Earth
We used the BusKote Flexi-Clear product: https://www.hytechsales.com/prod60.html
You can call the company with any questions, they are quite helpful. When I did call to ask why the finished roof had a slight yellow tint, they said I applied too much.
For what it's worth, the yellow tint has seemed to fade over the last year. It's in storage, can't hop up and look at the roof, but the last I saw it looks pretty uniformly off-white now.
05-10-2020, 09:55 AM
1990 25' Excella
Sisters
, Oregon
Finally ready to paint roof
I’m getting ready to paint the roof of my 1990 25’ Excella. I’m resurrecting this thread to check on paint. Is there a single paint that is recognized as the very best? And what type of paint do you recommend? Rubber, vinyl, etc?
Thanks!
John
John Audette
05-10-2020, 10:20 AM
1976 31' Sovereign
Oswego
I would like to use buskote on my 76 AS,are there any special things to do with roof such as sanding etc. before applying, I don't need to seal rivets or seams. Bill
05-10-2020, 10:22 AM
1990 25' Excella
Sisters
, Oregon
Bill...
My understanding from reading here is that thorough sanding should be done, using at least 220 grit. And most recommend primer, but not all.
John Audette
08-21-2020, 04:18 PM
The Joymobile
2011 22' Sport
MERIDEN
, CT
I used Henry's roof seal coating on my canned ham. It worked very well and inexpensive.
I have a 2011 22' Sport and while I don't think it really needs a roof repaint, it may need a new skylight and a strong likelihood of a solar install in the coming years, so I'd probably repaint the roof at that time. It's probably last on my list of things to do.
10-12-2020, 05:24 PM
Green Valley
Use a good water soluable primer, Dunn Edwards makes one that will stick to anything, I would not sand the AS with anything unless I wanted to take the paint off. If your roof is in poor condition then maybe, otherwise first, wash it well with a good detergent, prime it, paint it.
We coat the roofs of our homes here in the SW with white 100% vinyl roof coating, it's about $110 for 5 gallons, that's prpbably enough to paint 5 AS's. It is amazing and will last about 5-7 years.
10-27-2020, 08:02 AM
1992 29' Excella
Virginia Beach
, Virginia
Hello aswell,
I'm going the same route you have. I ordered the Aqua Prime primer (1 gal.), the Bus Kote (2 gal.) and the Flexi-Clear (1 gal.) from Hy-Tech.
Besides reading about it in this thread, this is what was recommended to me by the Hy-Tech company person I spoke with. As I recall, the application instructions for the primer advised 1 thin coat using a 3/8" nap roller. The other two application sheets for the Bus Kote and the Flexi-Clear finish are less specific, advising the use of a "thin nap" roller and simply advising thin coats with a minimum of two thin coats of the Bus Kote and one thin coat of the Flexi-Clear. All of the application sheets advise using thin coats. When I asked the Hy-Tech person about what the "thin nap" roller meant she sought advice from someone and came back with I should use a 1/2" roller. Now I'm no expert, but I've done enough painting to consider a 1/2" roller as more of a longer nap roller. I've used 1/2" rollers for uneven textured surfaces such as popcorn ceilings, cinder block,etc. Hopefully no ones Airstream looks like that! All that said, I'm wondering how you applied your finishes and what advice you have in hindsight.
Also, how well did it cover and do you feel it covered the square footage advised in the literature?
What drying times did you experience?
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
10-28-2020, 12:33 AM
Experienced Learner
2000 34' Excella
Somewhere
, Earth
Originally Posted by Re-Pete
Hello aswell,
Well it's been a few years, but it seems I used a 3/8" roller (with a Wooster extension pole) for all three coats. I suppose you could buy a few 1/2" rollers in case you want the Bus Kote to be extra thick, but that would only work for the Bus Kote as the primer and Flexi-clear are too thin.
I applied 2 coats of primer one day, and two coats of Bus Kote the next, one coat of each before and after lunch. Due to the time of year, the direct sun, and the relatively low humidity at the time, it only took a couple of hours to dry enough for a second coat. The Flexi-clear was done a few days later as it rained the day after finishing the Bus Kote. It could probably be done in two days, but I wasn't in a hurry. Plus, scrubbing the roof clean (using Dawn dish detergent and a long handled car brush, going slow and careful enough to not slide off the roof), then taping off the edges, fans and vents with painters tape the first day took much longer than anticipated.
And looking back, I would have used a tarp or painters plastic draped over the sides when painting, as there was some minor splatter that got on the upper street side, probably from overloading the roller and being a little too aggressive. The important part is the Bus Kote, so I did apply it very liberally. There was quite a lot of the Flexi-clear left over, a little of the Bus Kote, and I used nearly all of the primer. The recommended amounts, for our 34', were pretty accurate.
We were in Southern California this September, and while the park electrical system was straining to keep up with the demand from everyone's AC units, we had our windows open, enjoying the breeze. It makes a huge difference, worth all of the effort.
Hope some of that helps.
