Old 09-23-2015, 03:01 AM   #1
sabegirl's Avatar
1991 25' Excella
Pine Bluff , Arkansas
Belt line trim removal and replacement on Excella
Name:	ImageUploadedByAirstream Forums1442998909.897630.jpg
ID:	248777 Can someone give me some guidance on removing & reattaching the beltline molding? I have found a 91 Excella that is being parted out and would like to possibly get the beltline molding and replace my rear corner damaged molding. Is it attached with rivets and if so what type? We have had good luck with a dent puller so I think most of this dent will come out. If I decided to buy new molding, how would you form the curve in the rear?
sabegirl is offline   Reply With Quote
Old 09-23-2015, 04:34 AM   #2
2000 30' Excella
Toledo , Ohio
It's held on by pop rivets .
woodfox45 is offline   Reply With Quote
I need a piece of belt-line trim... malconium Clearcoat, Exterior Paint & Trim 14 09-28-2017 11:01 AM
Sealing belt-line trim? Friday Clearcoat, Exterior Paint & Trim 6 06-20-2012 09:18 AM
Belt Line Trim Removal Advice urban71 Ribs, Skins & Rivets 3 10-27-2010 04:21 PM
Belt Line Trim Needed For 1956 F.C Dan Clayton Clearcoat, Exterior Paint & Trim 2 08-04-2006 09:47 PM
