Old 08-12-2016, 10:22 AM   #1
1973 25' Tradewind
Geneva , Florida
Belt line and rub rail insert 1973 trade wind
I have looked on various websites and found vinyl insert for the beltline and the rub rail molding starting with 1974. I have a 1973. Right now my belt line has just blue tape in it and my rub rail has nothing. Does anyone know if these vinyl inserts for 1974 and up will work on a 1973? Or should I just buy the blue vinyl tape that you can use on automobiles?
AuntieLori is offline   Reply With Quote
Old 08-12-2016, 11:49 AM   #2
1976 31' Sovereign
Oswego , Illinois
Google out of doors mart [AS dealer]or call them, they have all
kinds of rub rail matl. can advise what you need. or Inland Rv [also AS dealer] same info.
featherbedder is online now   Reply With Quote
Old 08-12-2016, 04:57 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
1973 and older used a painted stripe.
Old 08-12-2016, 06:30 PM   #4
Chuck's Avatar
1973 23' Safari
Images: 260
was gonna say...mine is just painted.
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-12-2016, 08:09 PM   #5
1979 23' Safari
Wayland , New York
I think the rub rail will hold the insert. Post a close up. If there are small 'channels' inside the top and bottom lips of the rail then the side tabs on the insert should slide into those to hold it in. See if you can slide a index card or something like it up into those areas to tell.
Old 08-22-2016, 07:52 AM   #6
1973 25' Tradewind
Geneva , Florida
Don't see any track that would hold the trim
I don't see a track to insert any trim. It would need to be glued in. Will probably just buy striping tape for now.
Old 08-25-2016, 07:53 AM   #7
OttawaValleyGuy's Avatar
1991 35' Airstream 350
Barry's Bay , Ontario
I have a 1991 Airstream 350LE Classic motor home.
I would like to clean and repainted the cast aluminum front grill.
Any suggestions would be appreciated Click image for larger version
Name:	ImageUploadedByAirstream Forums1472133189.644269.jpg
Howard and Ann Schutt
OttawaValleyGuy is offline   Reply With Quote
Old 09-02-2016, 08:28 PM   #8
OnTheFlyRoad's Avatar
1970 23' Safari
Denton , Texas
The inserts aged quickly. I don't know if the new ones are the same way. I am going with a custom width reflective tape in Airstream blue for mine. The more vivid at night the better, right?
OnTheFlyRoad is offline   Reply With Quote
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
Argosy belt line/rub rail end caps bkahler Argosy Motorhomes 3 10-12-2012 06:01 PM
Loose belt line and rub rail Flynavy Ribs, Skins & Rivets 0 07-11-2011 03:42 PM
Rub rail insert popping out a little in one spot... ericwarren Exterior Restoration Forum 4 10-19-2008 08:03 AM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 12:10 PM
