09-14-2014, 06:11 PM
Conroe
Bedliner spray on the top of the Argosy?
Anybody ever was thinking about to use a bed-liner spray on the top of the camper? I don't have a shinny airstream, I have an Argosy , so it wouldn't bother me, but I was wondering if somebody did it before?
09-15-2014, 08:25 AM
1977 Argosy Minuet 6.0 Metre
Katy
Greetings from Houston,
I am planning on doing the same thing to an old Spartan - to make sure it is sealed and durable. It currently doesn't have any paint on it and I was told that it would be necessary to etch the aluminum or the bedliner would eventually peel off. You should be OK since the Argosy has already been prepped for paint. I'm sure others will join in but I would think it is a good solution for you. Best of luck and look forward to hearing how it works out for you.
The road goes on forever and the party never ends... Thks to REK
09-15-2014, 09:01 AM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
If you sand it good with 80 grit paper it will stick.
If I were to bedline the roof, it would be with WHITE bedliner.
09-15-2014, 09:08 AM
1981 31' Excella II
New Market
, Alabama
Seems like it would be a bit heavy to me. If you need to repair or replace something it could get messy.
Perry
09-15-2014, 09:11 AM
Briarcliff
Rhino Liner
Believe Rhino Liner has come out with a product specifically for such..................
1966 T-27 Avion (Sold & missed)
2022 Escape 19
09-15-2014, 10:01 AM
2013 28' Flying Cloud
Central
, Canada
They have - here is a link...
Rhino Linings Corporation | News - Coatings Company Press
Trying to use my camera to create memories - not photographs!
09-15-2014, 10:13 PM
Conroe
Thank You for the link!
09-16-2014, 04:47 AM
Lin
, Ne
I seen Line-X spray Dupont vari-prime on a truck bed before they sprayed the bed liner.
09-16-2014, 07:45 AM
Curtis Wright
Eyren Haven
, South Jersey
Here is a VW complete Bed Liner.
09-16-2014, 09:45 AM
1966 26' Overlander
Woodstock
, Georgia
Invisible...awesome
09-16-2014, 11:23 AM
2022 Atlas
Homosassa
I would want to be absolutely that whatever is sprayed on must not be affected by UV. If it starts to deteriorate from UV it could be a challenge trying to remove the product.
09-17-2014, 07:04 PM
1972 31' Sovereign
Benton
, Arkansas
Here is some bed liner I sprayed on today,,,
I wouldn't use black on the roof though.
02-22-2022, 03:48 AM
1970 25' Caravanner
Corona
J. Morgan,
I realize this a very old post but I would like to know how well the spray liner held up? Also what preping was needed for this.
