bambi trim and aluminum sheet needed
Next spring, I want to do some repairs/spruce up. The lower molding, around the bottom of my 2000 19' Bambi, is a hard extrusion with a snap in filler. The flexible filler is losing its clear covering, so I want to replace it. Looks like it is just cut to length and pushed into place, after removing the old. Is this something I need to order through a dealer, or are there other sources for this material? Also, I need to locate some of the dark colored aluminum sheet that wraps around from the lower molding to the belly pan. I have a spot that has corroded through, and I want to rivet and seal a patch over it. Any ideas for a source for the dark alum sheet?
Otherwise, just looking forward to some fall weather trips to Wisconsin!
