Old 06-10-2015, 05:30 AM   #29
aquinob's Avatar
Portsmouth , Virginia
Boatdoc hasnt posted since 2013, so he may not be active anymore. But it would be nice to know wouldnt it?
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 01-08-2016, 06:21 PM   #30
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I painted my popup (needed something to camp in while reengineering the argosy) last year. It's a 82 starcraft with aluminum skins. I used Ace galvanized and aluminum primer. Then used Ace Rust Stop oil based enamel with a hardener. I sprayed it but considered rolling it. It came out great. So much so I'm going to put a custom paint job on the argosy for less than $500!
Matt
rugjenkins is offline   Reply With Quote
Old 01-08-2016, 06:36 PM   #31
penticton , British Columbia
What hardener did you use? and what quantity/ratio?
I will be painting my argosy 24 with the (Canada) home hardware Rust Coat paint. it s made by rustoleum but the great thing is... it come in gloss base so you can costumize the color. I just finish rolling 2 test panels with a nice Subaru World rally blue and it s a very nice finish.
I use 50/50 paint/mineral spirit and it took 5 coat for full coverage with wet sanding between every 2 coat. It will be time consuming on a full trailer but you can get it done for 100$....
jonnyo is offline   Reply With Quote
Old 01-08-2016, 08:55 PM   #32
rugjenkins's Avatar
1975 Argosy 28
Name:	ImageUploadedByAirstream Forums1452311308.047527.jpg
16 oz paint
Thinned 25% or 4 oz mineral spirits
With 2 tbsp or 1 oz hardener
Valspar enamel hardener
Matt
Old 03-21-2017, 10:06 PM   #33
Brian67's Avatar
1973 Argosy 26
Proctorville , Ohio
Very nice paint job I have 26 foot Argosy I'm thinking about painting the lower section metallic silver and off white upper. You have very nice rig. I'm so amazed the shape these unit continue to maintain. Extremely well built.
Brian67 is offline   Reply With Quote
Best way to hold roller shades bgarrison Upholstery, Blinds, Walls & Interior Finishes 8 04-07-2009 05:57 PM
tambour roller door/clock twinke74 Cabinets, Counter Tops & Furnishings 8 09-10-2007 05:33 PM
Zip Dee Roller and Slat Diameter? Silverfly Awnings 5 04-24-2007 05:53 AM
Bent awning roller repair gparker Awnings 12 03-09-2007 02:28 AM
