Old 07-27-2010, 05:52 PM   #1
1965 26' Overlander
Selma , Oregon
Application of exterior Blue (Vinyl?) trim
We have been unsuccessful in getting the exterior blue vinyl trim on our 1965 overlander to stay in the channel around the middle of the trailer.
Thanks for your time!
scootertate is offline   Reply With Quote
Old 07-27-2010, 07:44 PM   #2
tinhutjohn
tinhutjohn's Avatar
1974 29' Ambassador
London , Ontario
Images: 8
Is this the bumper strip about an inch wide?
If so, compress the two edges together at one end and then let them expand into the grooves on the upper and lower edges of the channel. Keep compressing and releasing as you work your way along the channel. It should slip easily under the edges.
If you are going to go from one end of the channel to the other, you should remember that this stuff shrinks over time. I suggest you cut it in the middle, leaving a gap. Place a short sacrificial piece in this gap. As the long pieces shrink, you just replace the gap piece with one slightly longer. No one but you and I will ever know.
74 Airstream Ambassador International
94 Burb Ontario plate "TIN HUT"
02 Jetta TDI
Logan the Large hairy Golden Retriever
It's a monocoque thing
You wouldn't understand
tinhutjohn is offline   Reply With Quote
Old 07-27-2010, 08:51 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
How long a gap piece? Like 6" or what?
Thanks!
Gary
Old 07-27-2010, 09:12 PM   #4
We just replaced ours this winter and a few days ago we notice a gap in the small strip that goes around 3 sides and was spliced due to it being over a full roll. The gap was about 5" wide so I'd say 6" would be enough.
Old 07-27-2010, 09:26 PM   #5
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
The original question was posted by an owner of a 1965 trailer. In that year, the "vinyl" was actually painted, not vinyl like in the 70's trailers.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-27-2010, 09:32 PM   #6
Unless the rub rail and belt line moldings were upgraded to the "insert" type, 65's used paint, as the moldings were not designed to hold any insert.
Old 07-27-2010, 09:42 PM   #7
Ahhh! Well that would make sense as to why it was not staying in...
Application of exterior blue trim on 1965Overlander scootertate Clearcoat, Exterior Paint & Trim 3 07-27-2010 07:58 PM
Exterior vinyl trim ryan3326 Clearcoat, Exterior Paint & Trim 6 09-20-2009 04:29 AM
Exterior blue trim insert Kajtek1 Exterior Restoration Forum 9 05-08-2008 10:46 AM
vinyl blue trim strip t&m Clearcoat, Exterior Paint & Trim 6 07-30-2004 10:21 AM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
