Old 01-22-2009, 01:07 PM   #1
art
aluminum skin question
I understand the type of aluminum airstream used on 60s and 70s trailers changed in the 80s to a type that does not polish well .can you tell me when that transition took place? thanks art
art is offline   Reply With Quote
Old 01-22-2009, 02:17 PM   #2
The old metal used from day one, and the metal Airstream changed to in mid 1982, polish equally well.
Old 08-07-2009, 10:55 AM   #3
1984 31' Sovereign
Randolph , Maine
I recently bought a 30' 1984 Sovereign. The exterior was not well taken care of. Parked under trees for a long period, it has brown and green organic stuff on the top. Thinking I can use water with bleach to remove like the house. I can tell the acrylic has peeled under that and further out from under it. Can I mask the large area off, remove the coating, clean and prep the aluminum, then spray paint a new coat of acrylic. I have auto painting equipment available. This will take more than a can of spray coating, obviously. Are there specs available for the acrylic. I don't think Airstream owns a petro-chemical plant, so it must be made for them under brand name. Thanks for any help.
Cushnoc is offline   Reply With Quote
Old 08-07-2009, 11:08 AM   #4
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
Airstream has "rattle cans" of Acrylic Clear available, they also sell a 2 part clear coat, 1 gallon of clear and 1/2 gallon of activator, but the mix is not 2-1 it is based on ambient temperature and humidity, the instruction sheet for it is 10 pages long...
Greg
Greg@AirLA is offline   Reply With Quote
Old 09-04-2009, 04:37 PM   #5
catmoore's Avatar
1973 21' Globetrotter
Strathroy , Ontario
Do 1973s have clear coat?
catmoore is offline   Reply With Quote
Old 09-04-2009, 06:25 PM   #6
1976 25' Tradewind
Erie , Pennsylvania
I would bet your 1973 has clear coat. It is probably burned off the top. However the sides, front and rear are surely hanging onto the clear coat.
rollingbubel is offline   Reply With Quote
Old 09-07-2009, 02:14 PM   #7
art
I agree
Old 09-08-2009, 10:33 AM   #8
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I understand the type of aluminum airstream used on 60s and 70s trailers changed in the 80s to a type that does not polish well.
The most noticeable difference between the two different kinds of aluminum is that the newer has more of a milled finish and the old is a smooth finish. Yes, they will both polish well - the end results will both be equally shiny. However, the later aluminum will take a bit more work because you have to smooth out the milled finish first. They also have a slightly different color, but unless they are side-by-side and both newly polished, you'll never see the difference.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-08-2009, 10:38 AM   #9
InsideOut's Avatar
1956 22' Safari
Images: 108
Don't think you ought to use bleach on aluminum...
Shari
Aluminum skin scotty2 Ribs, Skins & Rivets 2 01-07-2009 03:59 PM
63 Bambi Aluminum Skin Gauge kamo Ribs, Skins & Rivets 13 11-22-2006 08:33 PM
source for stamped aluminum skin str8strm Cabinets, Counter Tops & Furnishings 2 11-03-2005 11:28 AM
Painting the skin with aluminum paint.. sunrider Clearcoat, Exterior Paint & Trim 2 10-03-2005 12:58 PM
Need a piece of Aluminum Skin Navigator Ribs, Skins & Rivets 3 01-08-2004 10:50 AM
