Old 12-05-2010, 02:35 PM   #1
withidl's Avatar
2002 31' Classic
Houston , Texas
Aluminum Duct Tape Cosmetic Usage
Having just read the post titled “New Owner Needs Help With Belly Damage” and the recommended use of “Aluminum Duct Tape” to cover his belly pan holes I thought I would advise of an alternative cosmetic use of the aluminum tape.
As my 2002 ASCL aged the furnace and hot water heater exterior panels, which are painted grey, began to oxidize and stand out in a cosmetically offensive way. They had always been an “off color” grey from the aluminum skins which I also didn’t really like.
I considered painting them with aluminum paint but my experience with that paint has been that after a very short time it deteriorates and I wanted something that would last and be low maintenance.
I went to Home Depot and bought several rolls of the metallic Aluminum Duct Tape. I was VERY careful to only select rolls that were cosmetically perfect, i.e. no edge damage with a consistently smooth and un-blemished surface.
I then removed the panels and carefully unrolled sections of the tape so that no creases were created and carefully applied it to the cleaned panel surfaces, edge to edge, until I had “painted” the entire surface with tape.
I did this about 5 years ago and wax it along with the rest of the AS. Below are photos taken today.
Name:	Aluminum Tape Cosmetic 1.jpg
ID:	116599   Click image for larger version
Name:	Aluminum Tape Cosmetic 2.jpg
Name:	Aluminum Tape Cosmetic 3.jpg
ID:	116601   Click image for larger version
Name:	Aluminum Tape Cosmetic 4.jpg
withidl is offline   Reply With Quote
Old 12-05-2010, 02:41 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Nice! A lot cheaper than the stainless ones I bought!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-05-2010, 03:03 PM   #3
1972 21' Globetrotter
nc , North Carolina
i have used that tape for years for many things and found it realy sticks great and don't dry out.
rock60 is offline   Reply With Quote
Old 12-05-2010, 03:10 PM   #4
Kevin245's Avatar
Looks good...Really impressive on how well the finish is holding up.
Kevin
Eleanor Roosevelt
Old 12-05-2010, 05:54 PM   #5
dsrtgrls's Avatar
2010 19' Flying Cloud
Clarkdale , Arizona
my 2010 bambi waater heater door is discoloring and that would be a great fix if you would do it. you are a maaster taper. it looks great. thanks for the show and tell.
"Open paddock 9!"
dsrtgrls is offline   Reply With Quote
Old 12-05-2010, 08:29 PM   #6
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from Ga. . .around here we call it 600 mph tape, cause airlines use it to hold windshields in while the mastic sets up/ dries. Regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 12-05-2010, 08:41 PM   #7
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
I must say, this thread is very helpful. From the photos and your statement that the tape has had five years in service, still looks great, to the 600mph jet fact, I think I'll be working on some projects over the winter. Thanks!
Anne
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
How to remove high quality duct tape JoePfznik General Repair Forum 11 01-10-2010 11:04 PM
Removing Duct Tape Residue Lumatic Cleaning, Stripping & Polishing 24 01-11-2008 04:03 AM
Seeking advice on replacing butyl tape sealant on ridged aluminum SOB SilvrSausage Vintage Kin 0 09-22-2007 11:03 PM
Duct Tape Popup fireflyinva Off Topic Forum 10 12-05-2004 05:54 AM
speaking of "Duct Tape".... Chuck General Interior Topics 5 09-17-2004 08:24 AM
