Old 09-06-2012, 10:37 AM   #29
Originally Posted by perryg114 View Post
What about surface prep. Most coatings over aluminum require something like Alodine to etch and seal the surface prior to clear coating. I suppose that AS might have some special formula that is self etching.
Perry
Perry
NEVER, EVER, etch the exterior metal for the plasticote.
Simply wash the shell down, with a "HIGH GRADE" Lacquer thinner.
If you ever used an acid, of any kind, you will be sorry that you ever did it. It will take a couple of years to show up, but you will have created many water leaks, around the rivets.
Old 09-06-2012, 10:40 AM   #30
Originally Posted by AldeanFan View Post
Whatever they use and however they use it it's not working, paint or whatever should last more than 5 years on the roof of a trailer.
Just start polishing and get it overwith! If I'm going to have to spend money and effort to maintain my finish I'm going to have the most shine I can
As a side note, I coated the aluminum wheels on my '83 Mustang in 2004 with automotive clear with a flexiblizer added, those wheels look just as good today as the day I sprayed them.
Use whatever you wish, but experience would disagree.
The flaking of the clearcote is because it does not have a UV guard as part of the formula.
If it did, the clearcote would become purple.
The UV is what breaks the paint down, and causes it to age rapidly.
Old 09-06-2012, 11:19 AM   #31
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Rivet Plastikote
I agree with Andy, unfortunately the previous owner not only tried an acid wash on the left corner and discolored the aluminum badly, but when that didn't work he used a very nice Makita palm sander (that he left me) and scarred the crown for about 6 feet, and then used it lightly on the lower panels below the beltline. I concidered pushing him off a cliff but he's a nice old guy who meant well (and had poor eyesight). His quote it only needs a coat of wax on her sonny and it'll look brandy spanking new. GAHHHH
Wonder if I can polish the marvelous swirls out before softening the aluminum?
arcamedies is offline   Reply With Quote
Old 09-07-2012, 01:36 PM   #32
1972 27' Overlander
Denver , North Carolina
Ok, So I called Airstream, and what they said was use acrylic clear spray can. So I'm gonna try it. Andy said that some dealerships carry this stuff, so I called my dealership - Out Of Doors Mart in Colfax NC. Here is the part number if you'd like it 28174-W and their web address: Clear Acrylic Spray 28174W [28174W] - $17.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone! It's not cheap, but it is blended at Airstream. I'm gonna try it.
mccrosti is offline   Reply With Quote
Old 09-07-2012, 02:01 PM   #33
sandlapper's Avatar
1993 34' Excella
York , South Carolina
I have used the spray can on small problem areas on the top of mine. It seems to stop some of the peeling and has stayed on just fine for several years now.
I lightly scuffed the areas with a very fine scotch brite pad, then sprayed them.
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 09-07-2012, 07:19 PM   #34
1972 27' Overlander
Well John, that is exactly what Airstream support came back with this evening. So that is what I'll do. Not looking for perfect blend, but I do want to stave off the filoform as long as I can, before I break down and policy her.
Lucky Dave, Denver NC
Airstream MH for FT? kb0zke Land Yacht/Legacy Motorhomes 13 10-23-2016 07:28 AM
