Old 03-10-2011, 09:14 AM   #1
aname4me's Avatar
1988 25' Excella
Thunder Bay , Ontario
Airstream Logo in a jpg format, and the name of the blues
I own a 1988 Airstream Excella. I am getting an aluminum plate plasma cut with a flag and the Airstream logo.
What I am looking for is…
1) a logo…. The word Airstream (with the scrolly, writtten A). It would be nice if it was a .jpg. I am trying to cut out the word Airstream (from the aluminum plate) to match the same font and style as the one on the trailer.
2) the name (or number) of the two blue colors used on the trailer, so I can get a spray can mixed to match
aname4me is offline   Reply With Quote
Old 03-10-2011, 10:08 AM   #2
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
Here's a couple.
Not sure if this is what you're referring to. Was the entire logo done in script form?
Tom
Res nolunt diu male administrari.
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
TWaugh is offline   Reply With Quote
Old 03-10-2011, 10:21 AM   #3
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
Or is this the one? I thought this was only on the motorhomes.
Name:   Airstream logo script.jpg
Tom
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
Old 03-10-2011, 08:37 PM   #4
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
As a professional in the commercial print industry, i recommend that you get a vector image, not a jpg. Your plasma guy will thank you. Check brandsoftheworld dot com or call Airstream Marketing for the actual logo... You'll likely have to sign a release stating that you will be using it for non- commercial purposes. Good luck
Sent from my iPod touch using AIR Forums
Phrunes is offline   Reply With Quote
Old 03-10-2011, 08:51 PM   #5
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
What is the color names; just wondering.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 03-10-2011, 11:16 PM   #6
Ottawa , ON
Lots of people have used "Ford Blue" to restore the various plates on the TTs...
Old 03-11-2011, 04:01 AM   #7
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
This script logo was also used on Airstream Trailers from about 1985 (our '85 25' Sovereign had it) to about 1990 (not sure the exact final year). The 1984 Airstream trailers still used a block letter logo if my memory is correct.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 03-11-2011, 06:39 AM   #8
aname4me's Avatar
1988 25' Excella
Thanks for the Comments and Help. I was hoping this would be easy.....
The operator of the Plasma cutter says that the A's and R's are a problem. The centers fall out when he cuts. He likes the written Airstream (that I have on my trailer) because it has lower case r's, but also it has an "e" and two holes on the A.
Some how ideas have a habit of turning into lesson.
Old 03-11-2011, 08:19 AM   #9
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Bridging the linework to eliminate the "holes" is easy and will look fine.
I'll give a +1 to the suggestion that vector artwork be provided to you cutter. The results will be much cleaner.
I can do this for you if you would like.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 03-11-2011, 02:18 PM   #10
aname4me's Avatar
1988 25' Excella
DanB.... That is a nice offer. Could you?
Old 03-11-2011, 04:12 PM   #11
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
I just ran across the paint codes on the AS service site here: http://www.airstream.com/files/libra...c78db5c5de.pdf also: find a pantone book and use a swatch outside in natural light if the Centari color is not listed on the Airstream pdf... You are looking for a PMS equivalent, dont view the swatches on a monitor to select... Use the actual printed pantone book. Good luck
Old 11-30-2016, 07:43 AM   #12
1988 29' Excella
Above link generated 404. New link here: https://www.airstream.com/wp-content...c78db5c5de.pdf
mbutterfield is offline   Reply With Quote
blue, logo, paint
« Spots! | Top | Nyalac? »
