Old 01-02-2010, 03:49 PM   #1
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
AIRSTREAM emblem spacing
If someone could measure the spacing between the AIRSTREAM emblems it would sure help me out. I'm guessing around 1/2". My Globetrotter came with painted Airstream plates (severe corrosion under plates) but I think the emblems look better. I am making a drill jig but not sure what the correct spacing is.
Kip
Old 01-02-2010, 04:06 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I suspect the WBCCI page may have that information. If someone doesnt chime in I will try to dig up the instructions that came with my numbers.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 01-02-2010, 04:10 PM   #3
Aerowood's Avatar
Arvada , Colorado
I'm looking for the cast aluminum AIRSTREAM emblem spacing not the WBCCI numbers spacing, but thanks anyway.
Kip
Old 01-02-2010, 05:00 PM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Kip
Are you reffering to the individual letters that say Airstream on the front and rear or something else.??
I have a 70 Globetrotter that would most likely be the same.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-02-2010, 05:08 PM   #5
Aerowood's Avatar
Arvada , Colorado
Yes the individual letters that say AIRSTREAM on the front and back of the trailer. I'm not sure which year the letters came off of, as I obtained them in a trade.
Kip
Old 01-02-2010, 05:15 PM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Kip
I will try to get measurements tomorrow (if it gets above 20 degrees)You probably need a center to center number to allow the differences between letters
13 Ram 2500 TD
Old 01-02-2010, 05:26 PM   #7
Aerowood's Avatar
Arvada , Colorado
C/L to C/L would work or the the spacing between the letters at the closest point.
Kip
Old 01-03-2010, 12:03 PM   #8
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Kip
Here it is off the front of my 70 globetrotter
Overall length of letters 29 in. outside
its cold here, took a quick glance at the back and didn't see any letters.
Thought there were some so will check again.. I bought the darn thing in 82.. Should know these things
Spacing between letters at closest point . all are 1 inch
All measured at bottom except the "T" measures from top bar
Hope that helps.
I have seen a few of these trailers with the nameplate but think most had individual letters. Must be a story here
13 Ram 2500 TD
Old 01-03-2010, 01:18 PM   #9
Aerowood's Avatar
Arvada , Colorado
thanks
looking for '63 Tradewind emblem 1963tradewin 1959-69 Tradewind 9 11-10-2009 11:42 AM
Airstream emblem vcu70 Ribs, Skins & Rivets 2 06-11-2009 07:22 AM
Forum Emblem cooperhawk Our Community 32 02-22-2006 07:47 AM
Rivet spacing till Ribs, Skins & Rivets 2 01-29-2004 02:24 PM
