Old 05-10-2007, 03:45 PM   #1
1976 24' Argosy 24
Tucson , Arizona
Advice - cleaning aluminum extrusion
We're about to become owners of a 1976 Argosy 24 in pretty sweet condition.
It's been kept in the Arizona sun for the past 10 years and so is in need of a respray and a general cleanup, but all the hard-to-fix things look in great shape.
One of the exterior cleanup jobs involves restoring the beltline and rubrails. I already sourced the vinyl inserts from the helpful folks at Oasis RV in Tucson, but I was wondering what would be the best way to clean up and restore the aluminum extrusions that hold these inserts in place. After all, there's no point in putting new inserts into a grimy extrusion.
I'm thinking I'll clean these before the respray and before the insertion of the new vinyl.
I found some advice elsewhere for cleaning windows; Simple Green and _synthetic_ wire wool and I'm thinking that this will work for aluminum extrusions too. However, I didn't see any other threads on this specific topic, so why not start one?
Anyone out there have any other neat tips?
CampbellMcCa is offline   Reply With Quote
Old 05-10-2007, 06:12 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
If you go the steel wool route, use "0000". It's fine enough to not scratch glass, I haven't tried it on aluminum. Someone else posted here the other day saying he uses 0000 steel wool with a product called (I think) Gord's on his aluminum wheels and trailer.
I would test in an inconspicuous place.
Dave
Fyrzowt is offline   Reply With Quote
Old 05-18-2007, 01:43 PM   #3
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
I have used 0000 steel wool with acetone on aluminum rails and it has worked quite well. I have also used "Tool Box Polish" from Lowes found in the hitch and trailer section with steel wool. Both processes have worked very well.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 05-18-2007, 02:19 PM   #4
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hi,
Welcome to the forum, I see anther Tucson is on ,that is great. I get lonely some times. Are you permanent resident or are you here for the winter? We live not far from Old Tucson studios.
On my AS I just used buffing compund before replacing the trim. Then I waxed it all.
Regards Russell in sunny and hot Tucson Az.
RUSSELL is offline   Reply With Quote
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
Stripping paint off aluminum tin can luv General Interior Topics 4 04-18-2004 09:32 PM
Durafix aluminum repair 83Excella General Repair Forum 1 03-22-2003 07:03 PM
Cleaning hubcaps Dave-O Wheels, Hubs & Bearings 1 11-22-2002 05:34 PM
aluminum restoring rdm Cleaning, Stripping & Polishing 1 02-27-2002 11:37 AM
